Introduction
0 Members and 1 Guest are viewing this topic. Read 1479 times.
pfradale
Introduction
« on: 6 Jan 2005, 12:03 pm »
Aloha all,
Paul Fradale here. Stumbled across this site tonight, hard to believe I had not seen it before.  I moved to Japan from Hawaii in August and am the tech coordinator (read: lab geek) at a small international school.
I purchased the mono extremes and tempest with remote (the plain black one) from Klaus prior to my departure.  At my request he built and biased them for the 100V/60Hz power here and my custom speakers. I built a pair of MTM-configured Lambda Unity horns which you can see if you hit the gallery page on the Lambda site; iirc, Nick dubbed mine the "monoliths".
I just bought a (used) Sony SCD-1 at a local shop, and all I can say is wow.
I thought the Tempest/Monos sounded great before, but the SCD-1 brought it all to a new level.  Serious chicken-skin here, folks, and I mean that literally.  Much is made of system synergy and the combo I have now has it in spades.
I listen mostly to jazz; right now I am listening to McCoy Tyner's Land of Giants, and the speed and control of the bass is astounding.  Earlier I was listening to the SACD Kind of Blue and was immediately struck with the air and shimmering quality of the cymbals. Listener fatigue looks to be a thing of the past.
Anyway, I just wanted to introduce myself and let Klaus know how pleased I am with the system.  For those considering the jump: do it.  Odyssey products really are a delight to own.  I read a few threads here about sources, and can heartily recommend the SCD-1 in conjunction with an Odyssey system.  They were discontinued in the US, I believe, but can be had used in the $2.5KUS range.
One last note: the only fly in the ointment for me has been the homely black remote.  I see now there is a Symphonic remote available, but it appears to have a plethora of buttons for other gear.  Since I only need volume control, I am working on a remote of my own.  When it is done I'll let you know how it turned out and what it would take to make one yourself.
jcoat007
Introduction
« Reply #1 on: 6 Jan 2005, 01:26 pm »
Welcome and congrats on your system.  Sounds great!!!
Please keep us informed on this remote.
Do you know the code for programming the volume control into a universal remote?
pfradale
Universal code
« Reply #2 on: 6 Jan 2005, 10:53 pm »
Sorry, no.  According to the threads I've read, there is no code; the only option is to get one of those remotes that can learn by reading the IR directly.
My approach is different:  I am a woodworker, so I am making the body of the remote.  The next step is to either get someone to "read" the pcb and draw up a schematic for me which I will use to solder up a new board using the old bits, or find a shop which will make the simplified board for me.
Brian
Introduction
« Reply #3 on: 6 Jan 2005, 11:05 pm »
Hi
Welcome to the Odyssey-Circle here at AudioCircle.
Regarding the remote, i would imaging that putting the electronic from the old remote into your new DIY-remote would be the best way to go.
Brian
