For Sale: Accessories
SOLD: Jensen Transformers Iso-Max CI-2RR - 2-Channel Ground Isolator
0 Members and 1 Guest are viewing this topic. Read 658 times.
danvprod
9 May 2018, 08:29 pm »
$150
SOLD
shipped to your door.
Used this to cut down on some hum to my sub amps from the integrated amp I was using. I recently upgraded amps and no longer have the hum issue. $199 retail. Very nice Jensen transformer inside. I did not notice a detrimental effect in system and it removed nearly all of my 60 Hz hum amazingly.
More details:
https://www.bhphotovideo.com/c/product/1344649-REG/jensen_transformers_ci_2rr_line_input_isolator_stereo.html
Eliminates hum and buzz caused by ground loops
Extended frequency response from 10 Hz to 40 kHz
Less than 2° phase deviation at 20 Hz
Plug and play easy to use – no power required
Made in the U.S.A.
Last Edit: 15 May 2018, 12:50 am by danvprod
gregcss
Re: FS: Jensen Transformers Iso-Max CI-2RR - 2-Channel Ground Isolator (RCA In/Out)
9 May 2018, 11:03 pm »
I used an ISO-Max in a previous system and it worked very well to eliminate hum with no noticeable (by ear) degradation in sound. Good luck with the sale.
Last Edit: 10 May 2018, 12:53 am by gregcss
