FS: UTC C-2080 Moving Coil SUT Step Up
0 Members and 1 Guest are viewing this topic. Read 2096 times.
Jeff V.
« on: 4 May 2018, 02:01 pm »
UTC C-2080 Moving Coil SUT Step Up.  Ratio 1:30 with 100 ohm Primary & 100K Secondary.  Very popular SUT in Japan.  I've been using this with my Ortofon Gold SPU with very good results.  Price $300 OBO.
orthobiz
Re: FS: UTC C-2080 Moving Coil SUT Step Up
« Reply #1 on: 10 May 2018, 01:45 am »
Any idea about a Denon 103? I think it needs 40 ohm. Sorry I don't know all the lingo, but was is 100K secondary? A switchable setting?
Thanks.
Paul
Jeff V.
« Reply #2 on: 10 May 2018, 04:26 am »
Thanks.
Paul
Hi Paul,
from what I've read the DL-103 likes a 1:20 ratio and the 103R 1:40 ratio. The turns ratio of the step-up transformer multiplies output voltage by its ratio.  The UTC C-2080 should work well with both the DL103 & 103R.
This Step Up does not have a switch because it only has a single primary of 100 ohms.  The primary receives the input from the cartridge and secondary refers to the output.
Thanks for your interest!
orthobiz
« Reply #3 on: 12 May 2018, 01:59 pm »
Thanks Jeff. I'm still wary about the 40 v. 100 ohm thing.
Are there links to this product on the web?
Paul
Jeff V.
« Reply #4 on: 16 May 2018, 02:45 am »
Paul
Not much on the net about these transformers.  I had read about a couple of Sutman SUTs using these transformers with SPU's and DL103s with good results.  Maybe more info in Japan since these are more popular there.
