Vancouver Audio Fest 2018
0 Members and 1 Guest are viewing this topic. Read 1256 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 3 May 2018, 04:57 pm »
SUBJECT: Vancouver Audio Fest 2018 – Bryston Demo
Vancouver Audio Festival
by Rafe Arnott
Sonus Faber is an Italian loudspeaker brand with a storied history, and designs which have been lauded as timeless classics. Bryston is an award-winning Canadian high-fidelity manufacturer with decades of experience in amps, pre-amps, speakers, and electronics. What do you get when you put them together? As I found at Hi-Fi Centre during the Vancouver Audio Festival, you get a musical pairing that seemed to balance each other out quite nicely.
Like many Sonus Faber speakers I’ve heard over the years, the Serafino Traditions that were singing with the Bryston stack seem at ease with most amplification manufacturers, as long as the wattage output is of suitable heft, and the voltage rail of suitable grunt.
The Bryston 14B3 power amp outputs 600 watts into eight ohms, and seemed to have the Serafinos well in hand during the demos I sat in on. A BCD-3 CD player, BDA-3 DAC, and Bryston Digital Audio Player BDP-3 (with separate MPS-2 power supply) was feeding the big Italian three-ways a healthy diet of CD, and Tidal high-res files during the show, and the sound here was accurate, fast, and tight with just enough warmth to satisfy a tube guy like myself.
A track which stood out during my time in the room was “Hey Now” by London Grammar, and while there was all the air, space and decay around Hannah Reid’s voice that I’ve become familiar with in hearing this song on different systems over the years, there was a speed to the bottom end that I’d not experienced before. It wasn’t as deep as I was used to, but it was fast, and gripping, and ultimately, it was enjoyable.
I don’t listen to Bryston very much as a reviewer, or as just a music lover, but once again when I heard it through the Sonus Fabers at the Vancouver Audio Festival I came away with a renewed appreciation for just what this homegrown solid-state company (Bryston) can do with speed on attacking notes, bass definition, dynamics, and accuracy.
TJ-Sully
Re: Vancouver Audio Fest 2018
« Reply #1 on: 3 May 2018, 11:15 pm »
Hi James, thanks for posting. The Hi Fi Centre is a sweet place to listen to Bryston gear.
And that's a mighty nice looking stack...with a monster Torus in the middle!
Do you know if most folks (or Igor) connect the BCD3 into the BDA3? Or just run straight into the preamp?
I think i'd be inclined to use the BDA3.
What are your thoughts on this one James?
TJ
« Reply #2 on: 3 May 2018, 11:19 pm »
TJ
Hi TJ
No I was not there so not sure how they ran the setup.
james
TJ-Sully
« Reply #3 on: 4 May 2018, 09:58 pm »
hi james
when you do set up shows, how do you connect the BCD3? to the BDA3 or straight up to the preamp ? or both?
or it depends...?
TJ
« Reply #4 on: 4 May 2018, 10:22 pm »
I usually do both so people can compare.
James
TJ-Sully
« Reply #5 on: 5 May 2018, 12:57 am »
Thanks James. That would be an interesting comparison.
What, generally, are the observations most commonly expressed by the listeners?
