0 Members and 1 Guest are viewing this topic. Read 11207 times.
2. f. Desgracia, catástrofe.
The change in property and the hecatomb that I suspect is looming in the world of expensive class AB SS amplifiers... is to believe that traditional brands are pushing for policy change.Let is hope you are right!
Because the BIG class AB poweramps have bad measures and they are very expensive. And now, after more decades, there are a true alternative with much better specs and much lower price.It will cause the closure of many small businesses => pressures via advertising ... the current business model of high-end audio will suffer a shock. Knowing this they will try to stop it.It has happened before in other business sectors when a disruptive event occurs, as is the case.
You are wrong.If there are a product with buffer+class D+PSU and very good specs, you can only differentiate the sound with preamplifier.The BIG class AB poweramps are like the blue whales, the first ones in danger of extinction. After other whales. The disruptive element was the use of the harpoon gun and the big factory boats that made the costs much cheaper.
Why is there no popcorn smiley?
:popcorn:
