1999 BP25
0 Members and 1 Guest are viewing this topic. Read 2781 times.
mike678
1999 BP25
« on: 2 May 2018, 02:11 am »
I have the the BP 25 that came with the original small power supply, with the MP1 added to me, it is quiter and all, but...too damned much bass. Is there some regulation or resistance change somewere that compensates between the models that came with the small power supply and the MP1? The schematics I find on the website only show the post-MP1 schematics, so I can't find a difference.
  • The Demo is Everything!
    • http://www.bryston.com
Re: 1999 BP25
« Reply #1 on: 2 May 2018, 03:43 pm »
Hi Mike - email Mike Pickett - [email protected]
james
mike678
Re: 1999 BP25
« Reply #2 on: 4 May 2018, 10:10 pm »
I wrote email to service via the website, and to Mike directly. No response so far.
mike678
Re: 1999 BP25
« Reply #3 on: 13 May 2018, 08:22 am »
Still no response. Anyone have anything?
Re: 1999 BP25
« Reply #4 on: 13 May 2018, 09:14 am »
Too much bass! This is a embarrassment of the rich.
A two-way pocket loudspeaker will have few bass and may match your preamp.
mike678
Re: 1999 BP25
« Reply #5 on: 13 May 2018, 07:25 pm »
Yes, it can be an embarrassment of riches!
But too much bass causes loss of focus and, paradoxically, loss of the sensation and tone of the bass. For instance, you can lose the "growl" of a good electric bass if there is too much around 60 to 120Hz. I can manually compensate in the room DSP, but I would just like to find a preamp, or make this one be, actually transparent to the source. Every high end one I have tried has a rather gross flavor somewhere that does not sound like the source. Whatever glories they might have or add, they are NOT transparent.
The BP25 on the MP1 supply tends to thicken the sound, quite a bit more than on the tiny supply it came with. I HAVE used the trick of coming in on the tape in, which bypasses the buffer module, and that does help a bit.
I may change the output capacitors to film values that roll the bass off slightly, or sell the thing. Not sure which yet. The sacrifice would be losing the Bryston's great ability to drive long cable runs, but I don't have the need here.
rob80b
Re: 1999 BP25
« Reply #6 on: 13 May 2018, 08:06 pm »
I doubt very much that the BP25 and its associated power supply is the culprit here….it's about as linear as any pre-amp can be….it’s proportionately amplifying the source’s reproduced signal of the recording…I would definitely look elsewhere…speaker, speaker placement and room interaction come first to mind. Do you have sub a involved as the 60-120hz region is the most problematic with regards to seamless integration of the crossover. Looks like you’ve tried a few things but unless something inheritably wrong happened to the BP25 it really does not make sense???? :scratch:
mike678
Re: 1999 BP25
« Reply #7 on: 14 May 2018, 12:29 am »
This is noticed in comparison to running the Prism Orpheus straight into the amplifier, vs into the BP25. Also into the BP25 with its native (small) power supply, and into the MPS1. Very noticeable difference in each case. Also quite noticeable when going around the first buffer via going in the tape input.
So, differences are heard when the preamp is inserted , and all else remains the same.   What I am trying to fix here, if Bryston will tell me what changes they made when they went to the larger supply, is that bottom end. And if they did not make changes, but accepted that sound because it sold well, then just tell me so. The same discrete op amps are in the 1.5 phono stage and that is nicely balanced (the MPS1 was the power supply it came with, so it was made around it). The 1.5 is one of my favorite phono stages.
The BP25 was not QUITE transparent, tonally, with original PS, but was pretty close. With the bigger supply, its prominent in a gentle bell curve with a Q of  about .6 centered at 60Hz out to about 200 or so compared to the original source, the Prism. The amplitude is a few tenths of a db, which sound like nothing, but it is much more than most cable changes do, and over which us audiophiles will fight major wars! (Many cable differences are in the hundredths of a db.) The difference is that between a bass blur, and a well defined growl on stringed bass.
There is no sub, the speakers are DSP tuned to the room  with the Prism Orpheus as the source (its what I do for side money, I am quite good at it). Any flavor changes noted are relative to that baseline condition.
Re: 1999 BP25
« Reply #8 on: 14 May 2018, 12:49 am »
Hi Mike
As far as I know there were no technical changes in the MPS-1 larger power supply other than allowing for more connections (4 rather than 1) so more units could be used with a single power supply.
James
TJ-Sully
Re: 1999 BP25
« Reply #9 on: 14 May 2018, 01:12 am »
hi mike678 - do you still have 'too much' bass with the MPS-1 power supply?
mike678
Re: 1999 BP25
« Reply #10 on: 14 May 2018, 01:43 am »
Thank you James for the reply, but I meant the change in the preamp side of things to accomodate the different power supply impedance. Regulator, feedback, resistance, SOMETHING? Like how the BP26 sounds pretty darn flat on the bigger power supply and the BP25...not so much.
Yes, TJ I still have the same flavor difference on the BP25 with the bigger supply. It was built around 1998 or so, with the small ac transformer ouboard supply.
Re: 1999 BP25
« Reply #11 on: 14 May 2018, 10:45 am »
I will ask Mike but as far as I know there were no significant chages.
james
Mike Pickett
Re: 1999 BP25
« Reply #12 on: 14 May 2018, 01:33 pm »
Hi Mike;
Sorry for the lack of reply on this; I've e-mailed you directly as well, this morning...
Lots of folks, including myself, have used this preamp with a different power supply than it shipped with, and while I expect differences in noise floor and sound stage, a frequency response anomaly is difficult to explain.  We'd like to get your unit on the bench here to reproduce and correct this.
Mike
mike678
Re: 1999 BP25
« Reply #13 on: 14 May 2018, 02:05 pm »
Excellent Mike, thank you. I will get that info to you later today, the unit is packed away right now. It's pretty early in the morning here. On the one hand, its something that bothers me, on the other hand, it already gave me 17 years of service (it was a demo unit from the now-defunct Laserland). Very few things last that long.
mike678
Re: 1999 BP25
« Reply #14 on: 17 May 2018, 10:07 pm »
Well folks, the Mystery is solved! I measured the regulator voltages as per Mike, and all was well.
But in looking at the output capacitors I see that I had bypassed them all together (jumpered with a wire)  somewhere about 2003. I had read somewhere that they weren't needed as there was normally no dc offset (there indeed was none). This was back in my audiophile "Electrolytics Be Evile" days.   This was some years before finding out that bipolar electrolytics used in this manner have distortions quite a bit below -110db and simple 2nd at that.  I seem to recall I made this change just before getting the new power supply, though I can't swear to it.
I returned to stock configuration, all works as it should now. If you are tempted to bypass the outputs, don't.
Thanks again to Mike Pickett for giving me what I needed to check things out. Spectral and IM tests of all sorts of multiple tones shows this baby is clean as can be. At least into adc/dac loads.
Re bipolar electrolytics in unbiased coupling duty  https://linearaudio.nl/sites/linearaudio.net/files/Bateman%20EW%2012%202002%20mar2003%201uF%20electrolytic%20or%20film.pdf Page 12
Elizabeth
Re: 1999 BP25
« Reply #15 on: 17 May 2018, 10:21 pm »
WOW! wonderful you got it solved.  :)
mike678
Re: 1999 BP25
« Reply #16 on: 18 May 2018, 01:11 am »
Yeah, Mike got me thinking in the right direction, so I had to look for something else other than my pet theory. I am really happy now. *Jumps up and down repeatedly...*
rob80b
Re: 1999 BP25
« Reply #17 on: 18 May 2018, 12:00 pm »
We were  :scratch: on that one.
As I mentioned in another post, Bryston got my 10 year old BCD-1 fully functioning again..... it's reassuring to know they've got our backs. :thumb:
mike678
Re: 1999 BP25
« Reply #18 on: 18 May 2018, 01:14 pm »
As the caps are breaking back in the sound is getting nice and smooth. I left the preamp on very high into a turned off amp all night, woke up to a nice, lovely, smooth sound.
