determining baffle size, driver placement with a mystery driver
0 Members and 1 Guest are viewing this topic. Read 2252 times.
20Hz
First post- take it easy on me :)
I got a couple of vintage german 12" full range (I imagine) speakers with the intent of building some open baffle speakers just for fun. I'm realizing that not having specs like Q for the drivers and not having a windows machine to run basta has me kind of stuck.
Are there rough general guidelines for baffle size for a single 12" driver? I assume I'm going to have to do some experimenting, but I was hoping to have a rough idea of where to start.
JohnR
chips666
I use Visaton Nobox with Philips AD12202 http://www.visaton.de/en/products/archive/nobox-bb
Enjoy
JohnH12
  • John H
Without specs you can't be wrong  :D
With a big 12 inch your are going to lose constant directivity near 1,000 hz or so listening on axis will be best.  if you can accept that, then go with something easy like a 24 inch by 48 inch handi panel.  The wide flat baffle with give you some bass support without resonances from an H or U frame.  Mount the woofer top inside (mirrored) and enjoy.
Edit: I wanted to add this is going to roll off like a typical midrange so you would need support below 80 hz or so.
If it is a FR driver not a woofer, you will use it as woofer or as mid range?
