Goldmund Job 225 amplifier - SOLD
0 Members and 1 Guest are viewing this topic. Read 1975 times.
MttBsh
« on: 24 Apr 2018, 12:01 am »
I am the second owner, this Swiss made amp is in fine shape, I would rate it at 8. Comes with original packaging and power cord.
Price is $725.00, Paypal preferred.
Srajan Ebaen at 6 Moons describes the amp better than I ever could:
http://www.6moons.com/audioreviews/job/1.html
TECHNICAL DATA
 POWER
 Nominal Power: 125W on 8 Ohms per channel valid for the full range of AC voltage (incl 100V for Japan)
 Power RMS (Goldmund FPP Standard): 200W on 8 Ohms each channel at nominal AC line voltage
 Nominal AC line voltage: 115/230V
 Input voltage range: +/- 15 %.
 FREQUENCY RESPONSE
 These figures are valid for any level between 0 and nominal power.
 +/- 0.5 dB, 10 Hz - .1 MHz.
 +/- 3 dB, 2 Hz - 0.9 MHz.
 INPUT SENSITIVITY
 Nominal level : 0.75 V.
 Unbalanced only (RCA).
 51k input impedance.
 GROUP DELAY LINEARITY
 Propagation delay < 80 ns stable with frequency from 2Hz to 200 kHz.
 DISTORTION
 Figures valid for all levels from 0 to 25 V / 8 Ohms.
 Dynamic : TID < 0.01 % (- 80 dB).
 Static : THD < 0.01 % (- 80 dB).
 SPEED
 Slew rate : > 60 V/m s.
 Rise time : < 200 ns.
 NOISE
 Weighted ASA A : > 100 dB.
 OPERATING TEMPERATURE
 Room temperature : -30 to +40 degrees Celsius ( -22 to +104 degrees Fahrenheit).
 Internal temperature : +45 to +65 degrees Celsius ( +113 to +149 degrees Fahrenheit).
 POWER SUPPLY
 Nominal line voltage : 230 V
 Toroidal Power Transformer to minimize radiated noise
 2 separated power supplies (left and right)
 Maximum power consumption : 450 W.
 SIZE AND WEIGHT
 36cm (14.2") W x 24.5cm (9.6") D x 8.8cm (3.5") H. - Weight : 7kg (15.4 lbs) net.
 FINISH
 Dark Grey anodized metal.
« Last Edit: 24 Apr 2018, 04:05 pm by MttBsh »
Ictwoody
  • Art Director. Artist. Kansan.
Re: Goldmund Job 225 amplifier
« Reply #1 on: 24 Apr 2018, 01:51 am »
Is this switchable voltage? Or 230 only?
- Woody
MttBsh
« Reply #2 on: 24 Apr 2018, 02:18 am »
As far as I know it’s 230 only
Ictwoody
« Reply #3 on: 24 Apr 2018, 02:33 am »
Okay thanks. I think the earlier ones were one or the other. I think later ones have a switch on back.
Great deal for people needing 230V. GLWTS.
- Woody
MttBsh
« Reply #4 on: 24 Apr 2018, 02:40 am »
- Woody
I just checked and there is a switch on the back of the amp for 115V or 230V, so it is the more recent model, thanks for asking!
Matt
JackD
« Reply #5 on: 24 Apr 2018, 03:39 am »
I owned one for about three years and it is a really good amp and a steal at that price especially paired with the W4S STP-SE or similar preamp.
Ictwoody
« Reply #6 on: 24 Apr 2018, 03:45 am »
Same. I owned mine for about 2 and I loved it. I paired it with the matching Pre2. Killer setup and this is a steal. That's why I found myself WANTING, but not NEEDING it. If I had a system for it, I'd snag it...
- Woody
OzarkTom
« Reply #7 on: 24 Apr 2018, 12:43 pm »
I had mine for two years, loved it. This is a great deal.
