Hello from norway
0 Members and 1 Guest are viewing this topic. Read 1943 times.
Bartesam
Hello from norway
« on: 21 Apr 2018, 03:39 am »
Hello! Just a norwegian audiophile looking to for a setup that will work with my extremely polluted mains grid without a ton of conditioning or a regenerator.
Re: Hello from norway
« Reply #1 on: 21 Apr 2018, 03:43 am »
Welcome aboard Bartesam :thumb:
« Reply #2 on: 21 Apr 2018, 10:02 am »
Welcome!
Have you considered battery power?
Check out Red Wine Audio here at Audio Circle.
Phil A
« Reply #3 on: 21 Apr 2018, 01:04 pm »
Welcome!
JakeJ
« Reply #4 on: 21 Apr 2018, 02:16 pm »
Hello and welcome to AC, Bartesam.
Wind Chaser
« Reply #5 on: 21 Apr 2018, 05:30 pm »
Welcome.
OzarkTom
« Reply #6 on: 21 Apr 2018, 08:17 pm »
Welcome.
I solved my hash with two IFI Ipurifiers.
Nordkapp
« Reply #7 on: 22 Apr 2018, 03:08 am »
Welcome, but I am not going to give you my user name.
« Reply #8 on: 22 Apr 2018, 01:09 pm »
Greetings & Welcome to AC Bartesam   :thumb:
Bartesam
« Reply #9 on: 27 Apr 2018, 01:45 pm »
Welcome!
I checked up red wine audio, but it is being replaced by vinnie rossi, so I am looking at vinnie rossi.
I looked around for other batterypowered sollutions but, I think I will just have anxiety for the batteries dropping under the needed voltage all the time.
Bartesam
« Reply #10 on: 27 Apr 2018, 01:48 pm »
Welcome.
With my current setup I got an Ifi ipurifier, it fixed a lot of the problem, same did filters on a lot of appliances include the computer etc. I also got a dc offset filter that also improved thing, but if I am going to solved everything with my current setup I need a regenerator. But I though Id rather look at a battery or supercapacitor sollution instead.
rollo
  • Rollo Audio Consulting -
« Reply #11 on: 27 Apr 2018, 03:11 pm »
Vinnie Rossi LIO is a perfect solution. Regenerators will not solve your issue. Can you run a dedicated 20A line ? If so run it from opposite of panel from appliances. Good money spent. Then condition that line. Gigawatt, PIAudio Uber and Betabuss or others.
With the VR LIO no conditioning required and maybe no dedicated ilne either. However I still would install 20A line.
charles
Bartesam
« Reply #12 on: 27 Apr 2018, 09:49 pm »
In fact at least on noise issue requires me to use a regenerator. I am renting so installing a separate low impedance line is out of the question otherwise I would have done that years ago.
But I am probably just buying a lio, and continuing from there(if it's needed).
« Last Edit: 14 May 2018, 02:03 pm by Bartesam »
Bartesam
« Reply #13 on: 29 Apr 2018, 11:14 pm »
And by the way thanks for all the greetings.
Bartesam
« Reply #14 on: 14 May 2018, 02:04 pm »
Just to be specific, this noise issue I am troubled with, which requires me to get a regenerator is intermodulation distortion.
