Static/white noise in right channel of DAC
0 Members and 1 Guest are viewing this topic. Read 1054 times.
« on: 20 Apr 2018, 05:14 am »
I installed an old DAC (Pop-Pulse) to my desktop computer. I use the optical from the motherboard (Asus) to the DAC, then to a headphone amplifier (Keces) to some old headphones (Sennheisers).
It works fine, but then it has starts to develop static/white noise in the right side (no audio). If you reset the PC or reinitialize the output, it will work again. Is there a setting that could cause a conflict?
