THX specifications
0 Members and 1 Guest are viewing this topic. Read 693 times.
M3 EuroLTW
THX specifications
« on: 15 Apr 2018, 08:33 pm »
James,
It seems that all the THX ST range of amplifiers I have include the ability to set the amp to local or remote power on.
Was this a requirement for qualifying for THX designation?
It is clear that this was an option, independent of THX certification..... so a non-THX amp could be ordered back then with that option.
Alex
  • The Demo is Everything!
    • http://www.bryston.com
Re: THX specifications
« Reply #1 on: 15 Apr 2018, 08:55 pm »
James,
Alex
Hi
Yes that was the requirement as well as 28dB of gain
james
