SOLD -EVS modded OPPO 105D player - $1095 SOLD
0 Members and 1 Guest are viewing this topic. Read 1020 times.
RPM123
« on: 7 Apr 2018, 08:16 pm »
SOLD
Purchased brand new and modded by Rick Schultz of EVS in November, 2015. I had Rick perform the "all out two channel balanced and unbalanced mod" which cost $1820.  This really transformed the performance of the unit. Mods consisted of:
"Mod to 2 channel output board:
1. Change all 8 power supply diodes in the analog linear supply to great sounding soft recovery diodes.  This makes the sound more detailed, 3D and more musical.
2. Add two WA Quantum capacitor chips to the two large power supply caps in the analog stage.  Way more real and detailed.  Add four more small capacitor quantum dots to power supply caps.
3.  J-fet buffer output stage for both unbalanced and balanced outs:  This zero feedback j-fet buffer output stage is super, super pure sounding.  This output stage uses our hand made cascoded current sourced shunt regulator system.  Only one fet in the signal path.  No I-V converter, no op amps.  There is just one resistor, one j-fet and one coupling cap in series with the signal.  The resistors are super world class (better than any resistor I have ever heard).  The coupling cap is a JB JFX polyprop cap with a WA Quantum dot on it and it is bypassed by my modified Wima .33uf polyprop cap.  This output stage is more sonically pure than anything anyone else is doing, including tube/fet stages.  The only downside of this output stage is that it puts out just 1V RMS per phase. (output is 2v in balanced mode) If you have a preamp then you are fine.  However, if you are running the Oppo straight into an amp or into a passive line stage then you might not have enough gain.  The loss from stock is 6db.....maybe a couple of o'clocks on the volume knob.  This mod gives you modded unbalanced and balanced outs.
4. Add a WA Quantum Semi conductor chip to the two channel DAC.  More detailed and real.
5. Change 4 capacitors on the DAC power supply to better caps including 2 modified .33 Wima film caps and also add one WA Quantum chip to one of the caps.  Cleaner and more focused and real.
6.  Change the DAC clock to low jitter femto clock.
7. Damp regulator heat sinks for way more palpable sound.
There is $98 worth of WA Quantum chips added in this mod." and;
"Advanced  Mods :
1.  Audio Magic Pulse Gen ZX installed on AC input.  More 3D and pure and clear.  $400 installed .
2.  Add 4 WA Quantum chips to rectifiers and 4 more WA Quantum chips to some capacitors.  Cleaner, purer sound.  $100 installed .
3.  Change the switching power supply that is used for the main processing board and transport to a linear supply.  This makes the imaging and depth much better and allows for much cleaner transients, clarity especially when the music gets dynamic and just plain more real.  $400 installed.
4.  Add two Mad Scientist Neo Kegs to the AC input and replace AC input wire with Furutech PCOCC wire and the stock IEC with a Shurter IEC.  This gets rid of the last "digital grain" and makes it sound more pure.  Highly recommended.  $90 installed.
5. Black the underside of both CD covers and all around the laser assembly with flat oil based paint.  This makes all discs sound warmer, more musical and cleaner.  Damp the disc clamp with constrained layer damping material.  This makes the sound cleaner, clearer, faster and gives a better tonal balance. Damp the disc clamp holder and the transport cover with constrained layer damping material.  Way more natural, pure, detailed and real sounding.  Apply AudioMagic Blackout Paint (damps and shields) to the CD tray and then paint over that with conductive black paint.   Cleaner and more real.  $150.
6. Remove toslink output connector......way more pure sound.  Free.  You really need to have me do this!
All out two channel balanced and unbalanced only: $530 + $1290 = $1820"
The voltage switch was also removed.
The 105D has Tidal, Spotify, Pandora, Netflix and other apps built in, so this is truly a one box solution. Unit is in excellent aesthetic and functional condition.
Buyer to pay shipping from 94122. PP fee also unless using "friends and family" option. I have perfect feedback under Grk in Audiogon, US Audomart (RPM123) and Audio Asylum (fogger)
« Last Edit: 15 Apr 2018, 02:01 am by RPM123 »
