Need amp recommendation for BMR Philharmonitor
0 Members and 1 Guest are viewing this topic. Read 11707 times.
maty
Re: Need amp recommendation for BMR Philharmonitor
« Reply #40 on: 30 Apr 2018, 08:07 am »
W4S SX-1000  old class D
http://www.6moons.com/audioreviews/wyred/monos.html October 2008
[Big IMG] http://www.6moons.com/audioreviews/wyred/open_big.jpg
I can see a ferrite to the four speakers wires.
Do not buy them. Class D only with new technology.
« Reply #41 on: 30 Apr 2018, 10:34 am »
From my active speaker experience, go with what the designer uses (AVA), period.
Wives can be trained.  Is there such a thing as an add-on trigger?
artur9
« Reply #42 on: 30 Apr 2018, 11:59 am »
I have a power strip that has a trigger on it for some of its sockets.  panamax m10-ht
slava
« Reply #43 on: 30 Apr 2018, 01:02 pm »
I gotcha Maty, but I’m not sure how to tell whats comsidered new class D. Are the Wyred4sound  sti-500 mii new class D? Also, I see that PS audio would let me trade in my Parasound A23 at full $999 value for a S300, which is 150 watts and looks to be “new” class D.
I agree with you, but I doubt I will win this one. I did not have the correct cable and had to use the Parasound without a 12v trigger for a few days, I rather not have that headache again.
The issue with a power strip with a volt trigfer is that depending on the amp it might not be a great idea to turn it on and offer via the power strip it self. Also I would prefer to have it plugged directly into the outlet if possibe. Maybe Frank has a solution for my 12v trigger dilemma.
maty
« Reply #44 on: 30 Apr 2018, 01:18 pm »
Only the new class D are good to play very good records.
Woofer or subwoofer with old class D is OK but not the tweeter. If you listen only commercial music or films, the old class D is OK too.
S300 -> IcePower 300AS. From... 2004.
If you want to pay less $2000, only you have two options with new class D modules:
* IcePower 1200AS2
* Hypex NC500 + good buffer + good PSU
You can try to order some of them or AVA with trigger. Ask.
Which preamp do you have?
maty
« Reply #45 on: 30 Apr 2018, 01:19 pm »
Amplifiers with IcePower 1200AS2, class D module
https://www.audiocircle.com/index.php?topic=156237.0
Letitroll98
  • Too loud is just right
« Reply #46 on: 30 Apr 2018, 01:32 pm »
NuPrime doesn't use any of these modules for their in house class D amps, several are below $2000, a couple are below $1000.
maty
« Reply #47 on: 30 Apr 2018, 01:38 pm »
[Review] NUPRIME DAC-10H + NUPRIME ST-10 amplifier, from Poland
https://www.audiocircle.com/index.php?topic=156135.0
maty
« Reply #48 on: 30 Apr 2018, 01:40 pm »
charmerci
« Reply #49 on: 30 Apr 2018, 04:28 pm »
What is a 12V trigger and why is it needed/wanted?  :scratch:
slava
« Reply #50 on: 30 Apr 2018, 06:11 pm »
Thank you for the explanation, I think I understand a little better now. A 12v trigger allows the amplifier to be turned on by the pre-amp when it is turned on via the pre-amp's 12v trigger output.
Are the W4S ST-500 mark 2 also using old module, where do I find this out?
charmerci
« Reply #51 on: 30 Apr 2018, 06:16 pm »
Get yourself a SurgeX then. It may improve the sound of your system like it did mine.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l2632.R3.TR6.TRC2.A0.H0.Xsurgex.TRS0&_nkw=surgex&_sacat=86722
Charles Calkins
« Reply #52 on: 30 Apr 2018, 06:24 pm »
                   "Wives can be trained"
               Are you SURE!! about that?"
                               Cheers
                           Charlie
maty
« Reply #53 on: 30 Apr 2018, 07:08 pm »
I think it is simple learning:
ON
1º Turn on the preamp
2º Turn on the poweramp
OFF
1º Turn off the poweramp
2º Turn off the preamp
It is more complicated to use an AVR, a mobile or how to send photos from the messaging program  :P
