Primaluna Dialogue 4 poweramp
0 Members and 1 Guest are viewing this topic. Read 2202 times.
peckjed
« on: 6 Apr 2018, 01:14 pm »
Up for scale is a Primaluna Dialogue 4 tube poweramp. This amp sounds amazing and can take just about any power tubes you throw at it, even KT120's!
I have the original boxes, white gloves and everything you'll need. The amp will come with brand new TAD 6l6 tubes and sounds wonderful!
Only reason I am selling is because I picked up a lower power single ended amp for my high efficiency setup.
$1,800 1,600 OBO local pickup preferred (CT) but i will ship. buyer pays shipping.
PRIMALUNA DIALOGUE FOUR
The DiaLogue Four starts with the same basic topology as the top-rated DiaLogue One integrated amplifier.
Further improvements are realized from new driver and phase splitter circuitry. The result is no need for any negative feedback. This means even more natural tonality and better overall musicality.
The DiaLogue Four delivers 42 watts ultralinear, 21 watts triode, switchable on the fly.
Like all PrimaLuna amplifiers, it boasts:
Soft-start circuit Extends component and tube life by powering up the amp gently every time you turn it on.
Tube plate fuse Protects the amplifier output stage.
Adaptive AutoBias. Exclusive to PrimaLuna, this circuit monitors and adjusts bias automatically. Improved performance and better sound, with distortion reduced by 40% to 50% over conventional designs. Plug in virtually any power tube. Adaptive AutoBias will automatically adjust itself! In addition to EL-34s, you can use 6550, KT88, KT90, 6L6GC, KT66, 7581, EL37, and any of their equivalents.
Premium parts . Fully vented chassis, chassis-mounted ceramic tube sockets, Alps potentiometer, Nichicon and Realcap capacitors. WBT style speaker terminals. Gold plated input jacks.
Handmade with the finest point to point wiring, with workmanship equal to or better than any product you can buy at any price, period.
Chassis made of finely finished heavy gauge steel, and five step automotive quality finish. Each coat hand rubbed and polished. Removable tube cage included no charge.
Toroidal power transformer for low hum, and a front end that is dead quiet.
Conservative design runs tubes easy for long life.
Next we take the DiaLogue Four to new heights with:
Triode/Ultralinear switching. Allows you to switch how the power tubes operate on the fly, via a slim aluminum remote, allowing you to stay in your nice comfy seat while switching between the two modes.
Improved output transformers designed for wide-bandwidth and high efficiency. These heavy-duty transformers elicit incredible detail from top to bottom, lower the output impedance, and provide the amp with greater control over speakers with difficult loads.
Zero negative feedback makes for a more lifelike clarity and natural tonality.
Built to Western standards with PrimaLuna's standard-setting build quality and unparalleled reliability.
Specifications
Output: 42 watts x 2 ultralinear, 21 x 2 triode
Freq. Response: 10Hz-100kHz +/- 3dB
THD: Less than 0.25 percent @ 1 watt
2 percent at full power
S/N Ratio: 83dB
Input Sensitivity: 880mV
Power Consumption : 232 watts
Dimensions: 15.2" x 8.3 " x 16 " (WxHxD)
Weight: 63.8 lbs
Inputs: 1 pair RCA
Outputs: 4 and 8 Ohm speaker taps
Tube Compliment: 2 - 12AX7, 2 - 12AU7, 4 - EL34
« Last Edit: 16 Apr 2018, 01:56 pm by peckjed »
peckjed
Re: Primaluna Dialogue 4 poweramp
« Reply #1 on: 16 Apr 2018, 01:57 pm »
bump for price reduction !
peckjed
« Reply #2 on: 22 Apr 2018, 09:25 pm »
Bump!
