Bryston BDP-1 & exFAT
0 Members and 1 Guest are viewing this topic. Read 1546 times.
fado
« on: 27 Mar 2018, 08:59 pm »
Will the BDP-1 read external drives formatted in exFAT if the latest firmware is installed? My BDP-1 has an old version of firmware (? late 2012) and will not recognize an external drive I recently reformatted in exFAT but will read one that is FAT32.
fado
Re: Bryston BDP-1 & exFAT
« Reply #1 on: 27 Mar 2018, 09:01 pm »
I forgot to add that the external drives are 240GB SSD's.
CanadianMaestro
« Reply #2 on: 27 Mar 2018, 09:03 pm »
Won't FAT32 work with 240 SSD ?   :scratch:
Use an mbr partition. (works for me, with BDP-1 and -2)
unincognito
    • bryston.com
« Reply #3 on: 27 Mar 2018, 10:30 pm »
Any version of the Manic Moose (S2.XX) will read exfat, otherwise you'll either need to format the drive fat32 or ntfs OR update to manic moose.
Chris
fado
« Reply #4 on: 27 Mar 2018, 10:53 pm »
1. FAT32 does work with the 240GB SSD but I do have some 4TB HDD for which I think exFAT is supposed to be better. I want all formats to be uniform. Also, I either have to find a MAC to format FAT32 or go to an outside application which I do not like to do. Windows does have NTSF as well as exFAT formatting options.
2. It is time for me to update firmware because MPad no longer works and I am sure MPod is short lived.
fado
« Reply #5 on: 27 Mar 2018, 10:59 pm »
What is the most but well tested and stable Manic Moose version? I do not need the latest & greatest - just stability, ease, simplicity.
fado
« Reply #6 on: 27 Mar 2018, 11:07 pm »
Correction: What is the most RECENT but well tested and stable Manic Moose version?
unincognito
    • bryston.com
« Reply #7 on: 29 Mar 2018, 04:23 pm »
I would say that’s the most recent stable release.  The testing/development versions require users to go out of there way to install.  Generally the testing/development builds tend to key be buggy relative to there new features.
Chris
vengky
« Reply #8 on: 2 May 2020, 02:05 pm »
Chris
Hi Chris
My BDP-1 is running the latest S2.42 2020-04-15 (FAT32 works and its plays DSD thru the BDA3) but it still would not read ex-fat USB pen drives. Tried formatting using a Mac and WIN10. The usb drive is still not recognised even after a re-boot. Any ideas? Thanks.
VK
