23 or 29 db gain
0 Members and 1 Guest are viewing this topic. Read 1670 times.
bigbuj
23 or 29 db gain
« on: 26 Mar 2018, 11:34 pm »
Hi there own a 14b3 bdp-3 bda-3 , im getting a simaudio 740p preamp with xlr audioquest earth cables, behing the 14b3 should i put it to 23 or 29 db gain , any inputs would be appreciated
Elizabeth
Re: 23 or 29 db gain
« Reply #1 on: 27 Mar 2018, 07:14 pm »
Using XLR the 'standard' is to use the 23dB gain with them.
However either way is perfectly fine.
I have used 29dB gain with my BP-26 to 4B-SST² via XLR.. Mainly because it had more 'pop' and sparkle.
Though right now I am using the 23dB gain as it is a little more mellow.
Then the affect on your preamp volume control may help you to decide.
I would try it both ways to see which you like/
(though shut off the amp before flipping the switch..._)
CanadianMaestro
« Reply #2 on: 27 Mar 2018, 08:58 pm »
With my system, 23dB sounds smoother and allows me to use my preamp vol more fully. I can also flip the gain of my preamp with my remote (LS27 ARC). That's my preferred adjustment.
I mute my preamp before flipping to 29dB on 14B-squared.
Try both. Use whatever sounds better for your musik, like El. sez above ^.....
bigbuj
« Reply #3 on: 28 Mar 2018, 03:08 am »
thank you for your inputs
