Which 10B for biamping?
0 Members and 1 Guest are viewing this topic. Read 1177 times.
Crimson
« on: 2 Jan 2005, 12:58 pm »
I would like to biamp my three-way Magneplanar 3.6/R's which, according to multi-amping options from the manufacturer, would consist of a hybrid setup in that the internal passive mid-tweet XO is fed the high-pass at 250 Hz @ 18db/octave, and the low-pass goes straight to the bass panel (200 Hz @ 6 db/octave). Which 10B should I opt for? The sub or standard?
Thanks.
ec
« Reply #1 on: 2 Jan 2005, 09:37 pm »
http://www.bryston.ca/pdfs/10b_manual.pdf
I have a real old 10b (std) and it's lowest xover point (high and low pass) is 70 Hz.  I believe the sub version of the 10B has more xover freqs for sub type freq such as 40, 60, 80, 100, 120.
The std ver I have has a low pass and high pass for 200 and then 300 but not for 250.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 3 Jan 2005, 01:18 pm »
HI Crimson,
Yes the 10B Sub has the crossover points and slopes required for the Maggies.
james
