0 Members and 1 Guest are viewing this topic. Read 9564 times.
I'm searching for a power amplifier to pair with a McIntosh c712 preamp and Zu Omen Def speakers. I want it to be melodic and clear (not mellow and round) and with a good soundstage, capable of filling my big living room (12m x 6m) with powerful party levels sound - not necessarily ear splitting levels. Nearby I can purchase a First Watt M2, a McIntosh MC7150 or an Ampzilla 2000 (stereo) for a good price. I cant audition them at home with my system, so besides my personal opinion on the sound at the different shops, what do you have to say regarding these three models? Any of them is better than the others? Better sound? Better reliability? Any opinions?
IIRC, the Omen is a high efficiency, revealing speaker so higher power is not necessary. The Mac pre already is giving you a certain character that works well with high eff, revealing speakers. A little less detail, a bit softer than many others. The first watt, with 25 watts and a resolving but not brutal character, would probably be very nice.
I recommend doing some math before you eliminate any of your options.http://myhometheater.homestead.com/splcalculator.htmlAt a typical 10 feet listening distance, 25W gets you 108 dB at your listening position with your 101 dB/1W/1m sensitive speakers. At 108 dB, your party guests will risk hearing damage, much less be able to have a conversation...
Peak watts from F5 are higher. Go with the F5.
F5 isn't one of the OP's choices, unless he builds one. It is a favorite among builders because it is relatively easy build (compared to some of the other FW designs) and the cost to performance ratio is outstanding.I would caution, however, that the F5 can be relentless. Nelson has more or less said this himself. It is like a microscope of an amp. If there are issues in your setup and/or recording quality, it WILL let you hear it all. It just has a way of highlighting leading edges which unearths details like none other (good and bad). As those Zu speakers are on the "energetic" and detailed side, the F5 and Zu's (though maybe a nice electrical pairing) could easily be a synergistic mismatch sonically.
The F5 also doesn't have tons of gain (chart is here - http://www.firstwatt.com/prod.html). I had a friend who sold it and got a J2. He liked the sound but the gain wasn't quite enough.
Sensitivity: 98dB/W/mImpedance: 6 Ohm nominal
20 watts, random phase2 m -> 108 dB3 m -> 104.5 dB4 m -> 102 dB5 m -> 100 dB6 m -> 98.5 dB7 m -> 97.1 dB8 m -> 96 dB
