Finding Pi IP address
0 Members and 1 Guest are viewing this topic. Read 1512 times.
schmidtmike76
« on: 9 Mar 2018, 10:23 pm »
Can anyone help how to find a IP address I can’t figure it out.  I had a new router installed.
Thanks Mike
schmidtmike76
Re: Finding Pi IP address
« Reply #1 on: 9 Mar 2018, 11:01 pm »
I’ll delete this thread later but you need the Ethernet cord plugged it....idiot lol
Calypte
« Reply #2 on: 10 Mar 2018, 07:21 am »
In my case, it defaulted to 192.168.1.19.  I've left it there.
jkelly
« Reply #3 on: 10 Mar 2018, 02:06 pm »
If you open a terminal, (Under accessories), type
ifconfig
Jeff
schmidtmike76
« Reply #4 on: 10 Mar 2018, 02:16 pm »
It’s a love hate relationship.  When it works I love it but when I have to get techy with it I go downhill.
audioengr
« Reply #5 on: 10 Mar 2018, 05:17 pm »
Log into your router from a computer on the network - follow the instructions included with the router.  Look at the label on the bottom too.
Scroll down the menu to IP and MAC binding
Select ARP list
You will see a list of IP addresses for the devices.  Unplug your device and do a refresh and then plug it back in and do another refresh.  This is how you identify which one it is.
Steve N.
Empirical Audio
Grit
  • - Garrett
« Reply #6 on: 10 Mar 2018, 06:30 pm »
If you're trying to identify what device an IP address is assigned to, Steve N. has the most accurate method.
I usually google the MAC address and see if that will give me a clue. For example, I found that one device I couldn't identify had a MAC address that is in a range associated with Sonos. That made me realize I'd forgotten my Sonos was on the network.
Some routers will allow you to add or edit device names. I believe most/all Asus routers do it, and at least some Linksys routers do.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #7 on: 10 Mar 2018, 06:32 pm »
Hi
If you have a Apple device you can use a program called FING on the Apple store to find IP adresses - its free.
Also if you type in MYBRYSTON.COM in your browser it will show the IP address of Bryston BDP and allow you to connect.
james
schmidtmike76
« Reply #8 on: 10 Mar 2018, 08:17 pm »
Select ARP list
Steve N.
Empirical Audio
this made zero sense to me
schmidtmike76
« Reply #9 on: 10 Mar 2018, 08:47 pm »
Hi
james
thanks James this is going to save me lots of headaches this works and is simple
