0 Members and 1 Guest are viewing this topic. Read 8450 times.
It is highly unlikely that the StreamPlayer adds noise to a recording. Does the Oppo have a file browser? If so, try playing a track using the Oppo as a controller and the StreamPlayer as a NAS on your network. In other words, use the Oppo to play files stored on the StreamPlayer. The idea is to take the StreamPlayer and Roon out of the equation and test the results.- Jim
I did as you suggested with the Oppo and the noise is still there. As a matter of fact, now the noise is there no matter what is playing, or even if nothing is playing. Turning off the Salkstream stops the noise. If the Salkstream is on, the noise is there, and gets louder when asking the Salkstream to do anything (whether using Roon or the web browser access to the Salkstream). If I leave the Salkstream alone for a bit with nothing playing, the noise gets quieter. Btw, I made a recording of the noise if you want to hear it.I did discover something, however. If I disconnect the HDMI cable between the Oppo and the Salkstream, the noise goes away. So it seems using the HDMI connection introduces the noise (I tried 2 different cables, made no difference). Of course with it disconnected I can’t use Roon to play multichannel files through the Oppo. Any suggestions where to go from here?
UPDATE:I tried a cheater plug on the Salkstream’s 3 prong power supply and the noise went away. Yay! Is this a safe solution?
http://www.dslreports.com/forum/r28709428-Electrical-Tell-me-about-cheater-plugs
Thanks for the link. Hopefully Jim can provide a proper 2 prong power supply to alleviate any risk.
see the first videohttps://www.amazon.com/dp/B0002E4YI8/?coliid=I2I3VNO4OQRS43&colid=321FECHQA1Z6W&psc=0&ref_=lv_ov_lig_dp_it
Do you by chance have a cable box nearby?
UPDATE:I tried a cheater plug on the Salkstream’s 3 prong power supply and the noise went away. Yay! Is this a safe solution? If not, Jim, would it be possible to get a 2 prong plug power supply for my Salkstream III?Now the other problem. After about 9-10 minutes after booting up the Salkstream and connecting to the Oppo, the connection drops and audio stops via HDMI (it still continues to play fine via optical to my pre/pro). The only way to re-establish the connection is to reboot the Salkstream.When the Salkstream boots up, you can see it doing so on the TV. Once fully booted up, this message shows on the TV:There’s a bliinking curser next to “Login”.After 9-10 minutes passes, the curser stops blinking and audio stops. If I switch to another input on the Oppo, then back to the HDMI input connected to the Salkstream, there’s no message at all on the TV screen.So it’s as if the Salkstream is going to sleep at the HDMI input. As I mentioned, the music will continue to play via optical output, and Roon never shows anything amiss.Jim, or anyone knowledgeable about the Salkstream’s programming, is there a way to keep the Salkstream from doing this on the HDMI output?What’s really weird about the HDMI issue is I know this wasn’t happening when I first started ripping my multichannel DVD Audio discs to the Salkstream. I played music, and paused, quite a while without any issues. It started just the other day when I started ripping SACDs.Thanks in advance. I appreciate the input and patience helping me to get this working right.
Interesting product. I’ll keep that in mind. There is small cable box hooked to the TV (part of my Audio/HT system).
