*******SOLD******Auralic VEGA Dac
0 Members and 1 Guest are viewing this topic. Read 726 times.
mpv
« on: 8 Mar 2018, 03:27 am »
SOLD
thanks for looking :)
VEGA, the next generation digital audio processor, is developed with the goal of 'seeking for non-compromised sound'. With plenty of I/O ports and powerful function, it will become the kernel component of your high-end stereo system.
With Sanctuary Audio Processor as heart, AURALiC introduces several cutting-edge technology for VEGA: Megahertz upsampling algorithm up-samples all PCM music to 1.5MHz in 32bit; Femto Master Clock provides an ultimate clock precision with jitter only 82 femtoseconds(0.082 picosecond). Binding with other AURALiC's patented technologies such as 'ORFEO Class-A module' and discrete 'Purer-Power™ solution', VEGA will bring high resolution music playback experience to climax.
VEGA supports all high resolution music formats including DXD(352.8KS/s, 384KS/s in 32bit) as well as DSD stream at 2.8224MHz and 5.6448MHz. Five digital inputs include AES/EBU, coaxial(set of two), toslink and USB. The balanced and single-ended analog outputs can connect to power amplifier directly, adjusting volume in digital precision without dynamic loss.
The Flexible Filter Mode embedded inside VEGA has six modes, each contains several digital filters optimized for corresponding sampling rate. These filters are solely developed by AURALiC to optimize the listening experience for different music and format. VEGA allows its user to customize according to different music formats, tuning sound best to personal preference."
« Last Edit: 10 Mar 2018, 01:34 am by mpv »
