0 Members and 1 Guest are viewing this topic. Read 2191 times.
It's doing it again! Every once in a while the front Display on my BDP-2 fails to update to the song currently playing. I am listening to the next song, but the display is still showing the song that I just finished hearing. Has anyone else had this issue?Does it have anything to do with the size of the library?
Thanks for responding. It's connected to a network. I have created a (temporary) playlist and it is cruising through the songs and then after a while the display stops updating accurately. About half way through the next song, it catches up. If the music is directly connected (which it is via USB), I don't understand how the network can be a factor.
HiI will let Chris answer - I may be wrong but I have found that sometimes if the network can not find the next album art or artist info it lags behind.james
Unless cover art comes with a download, cover art never appears.
Same with BDP-1/2. I resort to Google the album, and save the cover image as "cover.jpg" in the album folder. Then MPad will display the cover art automatically.
freedb.org has what I think is called metadata -- movement numbers and tempos, first words of opera arias, etc. Freedb doesn't have album covers. Musicbrainz is worthless. There are no covers for any album I own, classical, jazz, or pop.
