dac 10 and SRC
0 Members and 1 Guest are viewing this topic. Read 4974 times.
Jye
Re: dac 10 and SRC
« Reply #20 on: 11 Apr 2018, 05:16 am »
then the SRC of the chip is disabled with maximum frequencies supported?
I can't comment on how the ESS Sabre chip works internally, and whether there is a SRC in action within the Hyperstream architecture. We setup the chip such that PCM and DSD goes in the way it is from the source.
giordy60
Re: dac 10 and SRC
« Reply #21 on: 13 Apr 2018, 11:25 am »
https://i.imgur.com/9Xxqtdi.png[/img]]
giordy60
Re: dac 10 and SRC
« Reply #22 on: 16 May 2018, 12:12 pm »
...... We setup the chip such that PCM and DSD goes in the way it is from the source.
chip mapping can be changed ?
if so, you should know the signal path before and after the chip: scratch:
