Exogal Comet w/Outboard Power Supply SOLD SOLD
0 Members and 1 Guest are viewing this topic. Read 1005 times.
sumoking
« on: 3 Mar 2018, 07:44 pm »
Well cared for Exogal Comet with Outboard Power Supply is an Extremely Musical DAC that is upgradeable and priced to sell quickly at $1,200.
http://exogal.com/index.php/products/comet-dac
The Exogal Comet is a high performance digital to analog audio converter (DAC) playing up to 32/384k and DSD. Just connect your computer, or other digital/analog source, and experience exceptional audiophile quality sound. The Comet DAC does everything you would expect a high-end DAC to do, including balanced and unbalanced analog outputs, digital volume control and asynchronous USB input
« Last Edit: 6 Mar 2018, 04:03 am by sumoking »
blownrx7
Re: Exogal Comet w/Outboard Power Supply
« Reply #1 on: 4 Mar 2018, 02:31 am »
"Well cared for Exogal Comet with Outboard Power Supply is an Extremely Musical DAC that is upgradeable and priced to sell quickly at $1,200."
sumoking,
Does it come with the original box and manual and all the accessories listed:
 Bluetooth Antenna
 BNC to RCA adapter
 Stick-on rubber feet
 EXOGAL SR-07 Remote control
TIA
sumoking
« Reply #2 on: 4 Mar 2018, 08:04 am »
I should have those...
I have the remote for sure.
I have upgraded feet from Herbies... much better
I’ll check for the the other pieces tomorrow am
And reply back.
Thanks.
sumoking
« Reply #3 on: 4 Mar 2018, 09:27 pm »
It has:
- Orignal double boxing
- Remote
- BNC to RCA connector
- Bluetooth Antenna
- I can throw in my set of 4 Herbies feet which sound better then the stock feet
