BDP-3 usage question related to playlist
0 Members and 1 Guest are viewing this topic. Read 898 times.
soundmax
« on: 2 Mar 2018, 03:20 pm »
Hello,
As you turn on the BDP-3, is it possible to quickly access a saved playlist and begin to play it, using the buttons on the face-plate (the same way it works with folders)?
I notice a difference, while I'm able to see both folders and playlists, only entering/playing folders it works, but pressing "play" on playlists doesn't seem to work.
Am I doing something wrong ?
Hoiman
Re: BDP-3 usage question related to playlist
« Reply #1 on: 3 Mar 2018, 05:18 pm »
I sometimes have this when the database isn't updated. Just have to wait or doing a new update and everything will work again.
unincognito
    • bryston.com
« Reply #2 on: 6 Mar 2018, 05:24 pm »
Hello,
This should be resolved in this Thursday testing release and the next stable release (eta unknown).
Chris
