Fuse type replacement for a Bryston 4B ST power amp
0 Members and 1 Guest are viewing this topic. Read 3212 times.
Larry Bourget
My fuses burned out what type are they for replacing.
Larry
Calypte
Re: Fuse type replacement for a Bryston 4B ST power amp
« Reply #1 on: 2 Mar 2018, 09:25 pm »
Can't you pull them out and read the engravings?
Grit
  • - Garrett
« Reply #2 on: 2 Mar 2018, 10:39 pm »
If it was me, I'd rather know the fuse types so I could order them. That way, I would only have to pull my entertainment system out once, rather than twice.
Larry Bourget
« Reply #3 on: 4 Mar 2018, 02:44 pm »
They are 7 amp fast blow, i contacted Bryston and the technician is sending me the 2 i need.
First issue i have ever had after 23 years of ownership, i would not think of buying any other Audio Equipment than Bryston.
Great Customer service.
Thanks for the reply's
Larry
Larry Bourget
« Reply #4 on: 6 Mar 2018, 03:23 pm »
I have a bigger problem with my 4B ST than i thought, the new fuses blew immediately. My amp is off to Bryston for repair, no issues for 23 years until the area power outage Feb.28,2018.
I have a question, is there a right or wrong way installing the 2 fuses , ..... like double A batteries ?
Thanks for your time.
Larry
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 6 Mar 2018, 04:09 pm »
Hi Larry
No it does not matter which way they are inserted.
james
