Do you want a reference or not?
0 Members and 1 Guest are viewing this topic. Read 8361 times.
Re: Do you want a reference or not?
« Reply #20 on: 25 Jun 2018, 09:53 am »
Next step: fully active (one amp per driver, with low voltage crossovers) like the professionals typically use.   :thumb:
cyberstudio
« Reply #21 on: 27 Jun 2018, 06:22 pm »
Typically, the Beryllium tweeter is paired with a larger midrange to move downward/benefit the mid/woofer crossover. I guess (just guessing) the tweeter/midrange has a shallow slope passive and the driver selection is likely optimized for near-field listening.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« Reply #22 on: 28 Jun 2018, 10:04 pm »
Yes, a larger mid could be used but I wanted to make a more compact cabinet for regular and nearfield listening. Tonally this is one of the best designs I have ever done (and that includes many!).
