0 Members and 1 Guest are viewing this topic. Read 8360 times.
For years the Tempesta has been your best Monitor, it does everything well; has it been displaced now? That looks like the Accuton C51 mid and Scanspeak Beryllium tweeter; what's the mid/bass?pawsman
Oh ... the Epico is powered?? How much will these beauties cost?Cheers,Lester
How do they sound?
Would digital go directly in? via USB or Tos? How would they connect to each other (both active?)Very interestingGreg
... Obviously I will be somewhat biased. ...
Seems like great alternative to choosing/buying a bunch of separates for someone looking to upgrade/startWould this be more or less plug and play from a digital source, ie easy for a beginner?
Will you be brining the Epicos to the upcoming NC Audiophile meeting?
My love affair with the larger powered speakers continues but one aggravation remains constant. Without a volume knob to control volume, and without a visual display to tell you what volume level you’re at, or what preset you’re on, you have to play with the remote buttons to find the right settings. Classical music is especially challenging with the very quiet passages suddenly changing to bombast. Without a visual display - as are on some digital amps or cd players - the unexpected bombast can easily rattle the windows. But ... if I knew that I was on setting 5, e.g., I wouldn’t worry that I had accidentally turned it up to 11. (The visual display would have to be on the remote, I guess.)Also, I’m assuming that there are amps in both monitors and thus, power cords for both monitors.Will you be brining the Epicos to the upcoming NC Audiophile meeting?
You're more than welcome to, Rick. Congrats on the new design - beautiful!
Rick, would you explain a couple things about the Epico design? My questions are:1. What is the amplification you use for this? 250Wx2, yes, but Class AB? Class D?2. What are the entire digital inputs for this amp? Analog inputs? XLR in?3. No brittle sound from the ceramic drivers? Most implementations of same seem a bit etched to me, but I assume that is more the design than the driver technology.Thanks, -dGB
