0 Members and 1 Guest are viewing this topic. Read 10278 times.
No, tube watts are not more powerful than SS watts. A watt is watt. Tube amps have a tendency to clip more gracefully than SS, but clipping is still clipping and a watt is a watt no matter how you slice it.
With all due respect I will disagree.W is just a mathematical calculation, its the result of Tension x Currrent.So different proportions of Voltage X Current can result in an Watt final.Example of different structures of a 30W figure:Amp X 10V x 3Amp=30WAmp Y 15V x 2Amp=30WAmp Z 7.5V x 4Amp=30WSo W is an imaginary power figure that does not exist in the electrical reality, what exists circulating in the amps circuits and loudspeakers are different amounts of voltage and current.Hope this help.
A tube watt is the same power as a sollid state watt. However tubes run hotter than solid state so their watts have a lot more warmth to them. This is why people sometimes get confused.
My problem with tube amps is the TUBES. They go bad, they explode and set your home on fire....Then you gotta replace the tubes... and your home needs a refurb....
I'm no engineer and even when things are explained by those who are, I am lost. I have enough education though to know a watt is a watt, period. Tube amps don't have to run super hot or suffer short tube life. It's all about design.
