Acoustat Panel as mid bass support
0 Members and 1 Guest are viewing this topic. Read 1007 times.
Bigtuna
« on: 20 Feb 2018, 06:04 am »
want to use some extra Acoustat panels as mid bass support for my RD-75 ribbon drivers.
They will need to cover the range of 80 to approx 350 HZ.
Will use a digital crossover with 48 db slopes and a separate amplifier to drive them.
I was thinking 2 panel on each side of the ribbon for a total of 8 panels for the stereo pair.
thoughts?
What kind o interface might work....a simple transformer?
Mike
Re: Acoustat Panel as mid bass support
« Reply #1 on: 20 Feb 2018, 06:11 am »
Moved to Planar Circle.
