SOLD: Consonance (OEM Rega RB250) tonearm + JA Mitchell weight, adjuster
0 Members and 1 Guest are viewing this topic. Read 2064 times.
erimille
Selling a well cared for, Consonance (OEM Rega RB250) tonearm that has been greatly enhanced before moving to much more expensive tonearms yielding only incremental improvements. Enhancements include JA Michell Techno Weight along with JA Michell VTA adjuster and finger lock nut for easy VTA adjustments. I'm currently not using this arm and simply too nice to be collecting dust.  $250 + shipping
« Last Edit: 12 Feb 2018, 02:23 pm by erimille »
blownrx7
Price? Location? Packaging?
TIA :D
erimille
 :duh: - original listing updated
WireNut
 I'd like to purchase this tonearm but I don't know how to mount it.
Do you have a template or dimensions from the center line of a turntable spindle to the C/L of your tonearm pivot?
I would need to have something like that in order to mount it correctly I believe.
Thanks.
erimille
Thanks.
The Rega RB250 Specifications over on vinylengine may give you part of the answer
https://www.vinylengine.com/library/rega/rb250.shtml
Effective length: 237mm
Overhang: 15mm
Offset: 22 degrees
Mounting distance: 222mm
Mounting hole: 23mm
Effective mass: 12g
Cartridge weight range: 4 to 11g
I recall in the past seeing various mounting templates online but haven't checked what options might be available now. I do recall vinylengine and various forums here being gold when building/designing tables in the past. Let me know if this works for you and next steps. Thanks.
WireNut
PM sent.
