FS: Jolida JD-505 Verastarr “Hot -Rodded”
0 Members and 1 Guest are viewing this topic. Read 1457 times.
blazin
« on: 1 Feb 2018, 12:43 am »
Very nice VeraStarr "Hot-rodded" Jolida JD-505 integrated amplifier. Amp has upgraded capacitors, resistors, and diodes in critical areas upping the performance of the piece significantly. The unit comes with upgraded KT-120's installed and nice metal body remote control. Here are some basic specs...
GENERAL:
Serious upgrade to the famous JD502 and JD502BRC
Soft-Start, with Easy-bias setting
Auto-protection mode and Stand-By functions
New enhanced high grade Custom Wound Audio Transformers
New enhanced circuit design for more delicate sound
New generation Jolida proprietary luxury chassis design
German grain oriented silicon steel core
Enhanced S/N ratio and T.H.D.
High quality audio potentiometer & gold plated RCA input jacks
Gold plated five way speaker connectors.
Top panel bias testing terminal with easy bias adjustment controls.
Full IR remote control
Detachable power cord (IEC)
TECHNICAL:
Frequency Response: 15Hz - 70KHz +/-1db (Full Bandwidth)
Rated Power Output: 60W x 2
Input Impedance: 100Kohms
Input Sensitivity: 300mV
Output Load Impedance: 4ohms, 8ohms selectable
Signal to Noise Ratio: >88db, rated output
Vacuum Tubes: KT88 x 4 (2 matched pairs) - power output;
12AX7 (ECC83) x 2 - pre-amplifier stage,
12AT7 (ECC81) x 2 - power driver stage.
Total Harmonic Distortion: <0.3%
Dimensions: 430 x 324 x 220mm (WxDxH)
Asking $1250.00
« Last Edit: 30 May 2018, 07:21 pm by blazin »
