New build help
0 Members and 1 Guest are viewing this topic. Read 2539 times.
prosh629
New build help
« on: 29 Jan 2018, 10:56 pm »
Hi all,
I'm new to speaker diy, been reading interesting project done by members here. Im interest in building an alpha 15a H frame with Dayton PS220. I know the H frame baffle dimension but not sure of the PS220 baffle dimension Th at go on top of the H frame. please help guide me to the path, Thanks
mkane
Re: New build help
« Reply #1 on: 30 Jan 2018, 03:44 pm »
  Not so sure this measurement is that critical. Offset the driver a bit and good to go. 18-20" wide x 2'???????? Mine is 20x40.
« Last Edit: 31 Jan 2018, 12:32 am by mkane »
richidoo
Re: New build help
« Reply #2 on: 30 Jan 2018, 08:08 pm »
Hi all,
Welcome to AudioCircle Prosh629!
The larger the baffle, the lower the center frequency of the baffle step (diffraction loss) and dipole cancellation. Choose baffle size so that these acoustic phenomena complement the FR of the bass unit and the room. Whatever baffle size you choose will affect the design of the crossover and EQ correction filters. There's no correct baffle size, as long as it's big enough to support the bandwidth you're trying to get from the drivers. Both your drivers are pretty large cones for their purpose, so you don't have to worry about too small baffle. Large baffle is always good, but room reflections against the rear and WAF do take their toll on very large baffles. Also, no point using a very large baffle to extend frequency response if you crossover without needing that extra extension from the baffle. Pick baffle size that complements the whole speaker design, in particular the driver cone diameter and crossover points and crossover slopes. SOmetimes you can save money on crossover parts by using the natural rolloff of the dipole cancellation (at -12dB/oct) as part (or all) of your high-pass crossover filter. You would fine tune that dipole cancellation rolloff with the baffle width.
Typically you would just extend the Alpha baffle upward to allow room for the FR driver and put the high frequencies at whatever listening height you prefer, usually ~40".
Use sound absorber on one or both of the inward facing sides of the H baffles so they don't slap echo at midrange freq.
You might want to put the FR (full range) driver offset from the baffle edges to distribute the baffle step diffraction across wider bandwidth. You have 3 sides to work with, since the 4th side is the floor with the Alpha. So place the PS220 so that the difference in distance from center of FR to the left top and right edges differ by same amount, say 3". So if baffle is 18" wide, place the center of the FR driver 6" from the left, 12" from the right, and 9" from the top edge, while center of FR is also at ~39" height, so baffle will be 48" tall. This offset of the FR driver will make a smoother freq response, and require a flatter baffle step correction filter. Keep the shape of the top of the baffle rectangular as that contributes to the smoothing of the distances to the baffle edge because of the corner points. You can simulate this to aid driver placement using The Edge   Put the Alpha all the way down close to floor to minimize floor bounce cancellation with the FR driver.
The baffle itself will vibrate in sympathy with the drivers bolted to it, and this can ruin the sound of the speaker. Your H frame legs mostly control this, but if the center area of the baffle between the drivers is not supported it will vibrate so you may want to glue some steel angles across the baffle between the side frames. Or glue a big porcelain tile to that rear baffle open space, as big as will fit between the drivers and side braces.
have fun!
prosh629
Re: New build help
« Reply #3 on: 30 Jan 2018, 11:19 pm »
thanks you mkane and richidoo for your reply. Hopefully I can get the project start this weeken. I will follow richidoo guideline. For now I have to reread richidoo reply over and over again. I hope to understand and obsorb the knowledge pass on to me. Thanks for the warn welcome, ps hope you can understand because my English is limit.
MJK
    • Quarter Wavelength Loudspeaker Design
Re: New build help
« Reply #4 on: 1 Feb 2018, 12:51 am »
Be careful, you really want to design the crossover to mate with the baffle size and driver placement. The baffle and crossover will act as high pass filters for your full range driver so you want to make sure it integrates well with the H frame's output. A small OB requires one crossover frequency and a large OB will probably want a different crossover frequency. You may have to attenuate the Dayton full range driver output to bring the SPL down to match the H frame's SPL value. If you are going active this is easy to tweak by ear, if you want a passive crossover then some measurements and/or design calculations are needed to get it right the first time.
prosh629
Re: New build help
« Reply #5 on: 1 Feb 2018, 01:39 am »
Thanks you MJK for your reply. I go active since I have no knowledge of designing a passive crossover. Also, can I use two Alpha H frame per side to bring up the spl to match the full range?
MJK
Re: New build help
« Reply #6 on: 2 Feb 2018, 01:55 am »
According to PE, the Dayton PS220 is 96.5 dB/2.83 V/m. My measurements of the Alpha 15A yield 94.0 dB/2.83 V/m. Putting two in parallel in H frames should get you pretty close to the PS220 SPL value. Having two 15" drivers per side yields a dipole speaker capable of sounding very big and dynamic. Use a good SS amp to drive the paralleled 6 ohm Alpha 15A woofers, it worked well for me for a few years.
