GRANITE AUDIO "Ground Zero" latest model #502 $0LD to Jordan T.
0 Members and 1 Guest are viewing this topic. Read 804 times.
mooncrikit
$0ld!...Granite Audio's "Ground Zero", their latest model 502, in absolutely pristine condition, more like a 10/10! Upgraded grounding cables are color coded (red, green, blue, yellow, black & purple...see pics) for ease in identifying what component each is connected to. If you feel the color coding is unnecessary, the color "shrink" tubing can be carefully removed with a straight edge razor. MSRP @ $600.00, being offered for $0ld PLUS USPS PRIORITY insured shipping & PayPal fees are on buyer unless using F & F option. Below is info from the web...
Lowers system noise floor.
Operates in the systems ground circuit only.
Does not interfere with the music signal path.
Matches the ground impedance of every system component.
Replaces dangerous "cheater plugs" with a safer solution.
Creates a balanced ground path without expensive house rewiring.
Great alternative for renters. Take it with you when you move.
The standard GROUND ZERO kit comes with four 5ft and two 8ft cables. The chassis will accept 12 cables.
Before you can set up and use GROUND ZERO to eliminate your ground loop problems and improve your systems performance with a lower noise floor, it is helpful to have some basic understanding of how GROUND ZERO works.
Ground loop problems generally begin when there is a difference in the ground potentials of the various components in a system. The ground potential of one component may be higher or lower than that of another connected component and the components ground path to earth ground, or ground impedance, may be higher or lower than that of the other connected component. The result of a ground loop is audible hum, usually 60 cycle, that sounds like a low bass rumble. The noise can be extremely objectionable if it can be heard over the music or during quiet passages. Since the noise is low frequency, it also robs your system of available dynamic power because the amps are wasting their resources by amplifying this audible signal. An audible ground loop robs system power.
These unbalanced components share a common ground bond between them via the shields of their interconnect cables, or via the ground wire of their AC power cords. The ground bond created by the interconnect shields is problematic because of the small gauge of the wires, dirty contact surfaces, and the sometimes low mechanical integrity of the outer grounding ring of cheaper RCA plugs. If your RCA plugs have a lose fit, you have a potential grounding problem.
The ground bond via the AC power cords can be problematic because the cords may be different gauges, have different contact mechanical integrity at the outlet, and have different distances to travel back to earth ground. All these variables can create differences in the ground impedance of each component and opens the door for ground loops and system noise.
This is where GROUND ZERO does it's work. It functions totally in the ground circuit, so there's no interference with the music signal path. GROUND ZERO first bonds all the components together in a central star location with identical wires & terminations. The wires are all of the same large gauge and ultra-pure OFC flexible copper for identical low-impedance ground paths. Then all the terminations are gold plated and soldered to the copper wires for low impedance and long life integrity. The chassis banana jacks are one-piece construction and internal wires are also heavy gauge & soldered. The toggle impedance balancing switches are the most expensive parts in GROUND ZERO . These switches are ultra-low impedance, less than 5 milliohms, and have silver contacts rated at an impressive 32 amps per switch for long life integrity. So, GROUND ZERO presents a super high integrity, and uniform ultra-low impedance matching system for your components.
The back of the GROUND ZERO chassis is divided into 3 sections and each section has it's own dedicated impedance switch. This feature divides your system into 3 subsystems. The three sections are clearly identified by 3 different colors of banana jacks. Any 2 components connected to the same color banana jacks will always have their GROUND ZERO cables at the same impedance, regardless of the position of any of the toggle switches. So, components connected to the same color jacks are bonded to each other at the jack itself at the lowest possible impedance, and this will not change with changes in switch positions.
Components that are connected to different colored jacks have their GROUND ZERO cables isolated by the corresponding toggle switches. This feature allows the user to match and balance the different ground impedances of each section to each other section. Each toggle switch has 3 positions it can be set to. High, Low, or Medium Impedance. These settings determine the ground impedance bond between the 3 sections. With 3 sections, 3 switch positions, and the possibility to plug components into different sections; there are a minimum of 27 different impedance matching settings. Because of the basic design of GROUND ZERO , many different settings will actually yield the same noise floor readings on a decibel meter. But, one or more different settings will give the lowest audible & measurable noise floor. So, relax, there's not 26 wrong settings and only 1 needle in the haystack. Depending on your system, you will probably find that you will get 3 to 5 different results. A result is a difference in the audible or measurable noise.
You are now ready to install GROUND ZERO . Make a mental note of your systems noise floor before installation. Be sure to start with your entire system OFF and all components turned OFF. The GROUND ZERO chassis can be located anywhere. Each supplied ground cable has a high quality banana plug on the end that plugs into GROUND ZERO . The other end of the cable has a stepped spade. The step allows this spade to connect to a variety of different sizes of screws and terminals. The spade end connects to your components. It's very important that the spade is only connected to the components chassis or terminals that are clearly marked "GND" or "GROUND" or are known to be grounded terminals. Never connect any GROUND ZERO cables to positive speaker binding posts, speaker binding posts, any posts marked with red stripes, or any other point that may not be a ground point. If you are not certain of your connecting points, you must consult the factory or other qualified technician before connecting the cables to your components. To avoid getting shocked by components that are faulty, do not handle more than one cable at a time and wear rubber or leather gloves. This safety procedure is necessary because your ground loop may be caused by voltage present on the chassis of faulty or improperly grounded components. This possibly present voltage is why "cheater plugs" are so potentially dangerous.
The cables are designed to be connected to your components chassis. The best way to do this is to loosen one of the chassis screws a few turns until the spade can slip between the screw head and the chassis. Smaller screws will allow the spade to insert to the tighter step. Larger screws and dedicated grounding posts will engage the larger mouth step of the spade. Tighten the screw against the spade. Connect one ground cable to each component chassis. The standard GROUND ZERO kit comes with four 5ft and two 8ft cables. The chassis will accept 8 cables. Custom length cables can be ordered from your dealer. If you have more than 8 components in your system, you can simply buy two GROUND ZERO kits and bond them together with the special two-kit cable available from your dealer.
Based on much testing in different systems and with vary different gear, GROUND ZERO is already laid out in the optimum starting configuration for 95% of our customers. The sections are clearly labeled for which components should be initially plugged into each section. Power amps and other high-power high-current devices should start out plugged into the section labeled "POWER AMPLIFIERS". Other components such as CD, DVD, tuner, DAC, transport, and other low-current source components should start out in the section labeled "SOURCE". Signal processors, preamps, line-stage amps, phono preamps, and other middle components should start out in the section labeled "PREAMPLIFIER".
Now with all your components connected, start with the impedance switches all in the "HIGH" position. Power up your system, but do not play any music. All settings will be tested with no music playing. Listen to the existing background noise of your system. You may turn up the volume to make the noise more audible, but remember to turn it back down when you're done with the setup. Now click the switches, one at a time, to each of their three positions. Listen for changes in the audible background noise. Some of the switch positions may actually increase the audible noise. But, don't be concerned. This is to be expected. Continue clicking the switches until you get the lowest audible noise. The use of a decibel meter will help you get the absolute lowest noise setting. Once the noise floor gets low enough it may be difficult to hear the differences between settings. This is because of the Fletcher-Munson Curve where your hearing is less sensitive at the lower bass frequencies including the 60 Hz ground loop hum. Contact the Granite Audio factory or your dealer for details on a loaner decibel meter.
We have been able to achieve a lower measurable noise floor with GROUND ZERO in every system tested so far. Even in systems with new properly wired dedicated 20A circuits with high quality 10AWG wiring in the wall & in the AC power cords, and each component on its own dedicated circuit. While this system yielded the least improvement, it did improve. And, unless you have an endless budget and are prepared for major house rewiring, GROUND ZERO is an affordable safe alternative. If you live in an apartment or are renting your home, rewiring may not even be an option.
You can also reconnect components to different banana jacks to see if this improves your noise floor even more. Wear gloves while doing this and only handle one cable at a time. Discovering the best final settings for the impedance switches will give your system the lowest possible noise floor that can be achieved by ground impedance matching, without rewiring your house or using dangerous "cheater plugs".
Additional Information:
International buyers are responsible for any taxes, duties, tariffs, fees and if lost, stolen or damaged in transit. Payment if using Paypal is by "friends & family" option only for non USA buyer...
« Last Edit: 7 Feb 2018, 10:53 pm by mooncrikit »
EquinoxDesignLab
Re: GRANITE AUDIO "Ground Zero" latest model #502
« Reply #1 on: 7 Feb 2018, 04:12 pm »
Sent you a PM
