FS: ieGO Power Cables - SOLD
0 Members and 1 Guest are viewing this topic. Read 675 times.
apstoltz
« on: 25 Jan 2018, 10:32 pm »
I have a (4) 3.5 feet ieGO Power Cables model L70530. These are excellent cables for any source. The L70530 itself is made up of 14 strands of individually insulated copper, silver plated copper and silver alloyed copper in different gauges for the Live and neutral line, and multi strand silver plated copper of the same gauge for ground. With copper foil (not aluminum like most other cables) for shielding.
What's more interesting is that the copper used is sourced from Furukawa (yes, that really expensive Furukawa), their 1020 Copper/Rose copper is rated at 4N purity.  It is then alloyed with 0.1% of gold before it is made into wire (all the copper in the cabling have been alloyed with gold) and use OCC casting process with diamond drawing die to create it.  The silver plated copper additionally receive between 120um to 240um of pure silver plating (plating thickness depends on wire gauge).
It is then cryo processed in liquid nitrogen for 22 hours @ -240C/-400F to relieve all internal stress, and then bundled up to make the wire.
Solid bass with excellent control, extension and decay.
Good imaging and focus with a lot of details.
Large and finely layered sound stage.
Enhances vertical sound staging, not just horizontal.
Very smooth sound all around, no undesirable sharpness anywhere.
Perfect to tone down the unnatural brightness of some class D amps or other equipments.
One of the best bang for buck cable of all time.
######SOLD######
$45 shipped per cable. CONUS
« Last Edit: 26 Jan 2018, 02:51 am by apstoltz »
apstoltz
Re: FS: ieGO Power Cables
« Reply #1 on: 26 Jan 2018, 02:50 am »
-----All Cables SOLD------
