New (to me) BDP-1 Stuck on S2.05
0 Members and 1 Guest are viewing this topic. Read 1266 times.
jphabc54
« on: 23 Jan 2018, 02:06 pm »
Hi all -- I just took possession of a used BDP-1.  I've successfully booted it and can log into the web interface.  I've also mounted a NAS and streamed some (great sounding) music.
Unfortunately I'm having some trouble updating the firmware.  It arrived installed with S2.05.  On the firmware update page, a stream of subsequent updates are listed (up to S2.36), however when I run the update I receive the error pasted below.  After some more troubleshooting I suspect I'm not getting access to the internet, but it's hard to tell (I'm having no issues with my local network).  I've confirmed the network settings (correct gateway, subnet, and local IP in DHCP).  I've tried the BDP-1 on two different ethernet cords on two different switches.  FWIW, I'm also having issues putting the device in service mode (seems to stall out, which again makes me wonder if I'm not getting good access outside my local network).  Any advice?
Downloading firmware filesystem
undefined% @undefined
Downloading boot drivers
0% @0
Downloading vmlinuz image
Running Filesystem Check: 4faeeee32acfef8c42caf6f42c9c2fcb /lib/live/mount/medium/live/filesystem.new
:Filsystem Check Failed: md5 values different
Should Be:
Calculated: 4faeeee
You should try redownloading this version of the firmware and try again
CanadianMaestro
Re: New (to me) BDP-1 Stuck on S2.05
« Reply #1 on: 23 Jan 2018, 05:29 pm »
Try resetting to Factory Default, then download fresh the latest (or whatever) version of MM that you want to use.....?
jphabc54
« Reply #2 on: 23 Jan 2018, 08:19 pm »
Thanks -- I tried that a couple times but no luck so far.
artur9
« Reply #3 on: 24 Jan 2018, 02:28 am »
2 Ideas.
(1) Contact Bryston.  I bet they'll let you know how to update.
(2) The software, IIUC, is on some sort of flash card.  You can replace that.  But i don't know where you'd get the software to put on it.
Update:
This doc may help.
http://www.bryston.com/PDF/firmware/BDP_Manic_Moose.pdf
dznutz
« Reply #4 on: 24 Jan 2018, 02:33 am »
When will people realize that the bdp1 is quickly becoming obsolete
CanadianMaestro
« Reply #5 on: 24 Jan 2018, 03:07 am »
Well, it's been superseded by BDP-2 and -3.......
jphabc54
« Reply #6 on: 24 Jan 2018, 05:35 pm »
I contacted Bryston and they are working with me to fix it.  I realize it's a discontinued product, but--as long as I can get the latest build it's capable of running--it's all I need for my system right now.
artur9
« Reply #7 on: 25 Jan 2018, 03:29 am »
My BDP-1 is working great and I don't see any need to replace it.  I bought it used last year.
But I don't use it to store music.
