No highs with ortofon blue mc
0 Members and 1 Guest are viewing this topic. Read 722 times.
johnto
« on: 21 Jan 2018, 09:30 pm »
Installed. Ortofon Blue on VPI Aries Scout it has been used about 20 hrs the amp is a Parasound halo 2.1 integrated my problem is the nice highs i had with prior Blue Point  have disappeared, cymbals and such are very faint do I need a phono pre besides the on in my integrated or a sut.
restrav
Re: No highs with ortofon blue mc
« Reply #1 on: 21 Jan 2018, 10:08 pm »
is it properly aligned?
kingdeezie
« Reply #2 on: 21 Jan 2018, 10:11 pm »
It has been a while since I had a TT, but that sounds like the VTA is off to me. Check the angle, and see if that makes a difference.
johnto
« Reply #3 on: 21 Jan 2018, 10:31 pm »
Thanks It looked okay on VPI jig but I will recheck it.
