SOLD - Gustard U12 DDC
0 Members and 1 Guest are viewing this topic. Read 873 times.
PeteG
« on: 21 Jan 2018, 06:43 pm »
SOLD
Gustard U12 DDC Digital to Digital Conversion
I'm asking $SOLD plus shipping. PP F&F preferred
Increase the screen display, the sampling rate at a glance
Use XMOS programs to support 32B 384khz asynchronous 2.0 (USB recommended that ASIO output)
Using an independent power supply. Built-in sealing ring cattle, multiple sets of multi-level regulation. About the importance of independent power, I believe we all know.
Optimize the design of the audio clock circuit using 0.1PPM precision active crystal to provide a more perfect clock signal to digital audio. Provided for by the two crystals were 44.1 / 88.2 / 176.4 / 352.8Khz and 48/96/192 / 384Khz series rate signal only after the selected clock rate selected work, work another one audio clock stop, put an end to the mutual interference may bring work simultaneously when the two clocks.
A total of four kinds of output: Coaxial (RCA), optical fiber, AES / EBU, IIS (HDMI port)
Coaxial fiber AES / EBU output formats IEC60958 and AES3-r2009 standard limits the maximum support 24Bit / 192kHz; IIS can transmit 32B 384K
Smart switch, USB has a current interface to boot. Interface with the computer switch and switch machine (computer to be set off USB power failure), or unplug the USB cable directly to the shutdown.
Laser marking, never fade
Built-in smart switch, plug in USB automatically
Two 0.1PPM precision crystal 45.1584M 49.1520M
International voltage AC115V/230V, the need to manually adjust
Rigorous design, reasonable layout, elegant lines, solid materials.
Figures show that a mesh understand. DSD support 128, PCM supports 384K
Aluminum chassis, the drawing process, the body all black, black and silver optional panel
XMOS - U8 chip, support 32BIT / 500MIPS digital signal processing unit, the inside has eight cores.
« Last Edit: 26 Jan 2018, 01:32 am by PeteG »
inthemine
Re: Gustard U12 DDC
« Reply #1 on: 23 Jan 2018, 12:43 pm »
A couple of questions:
How old is the U12 ?
What is the general condition of U12 in terms of functionally and cosmetics?
PeteG
Re: Gustard U12 DDC
« Reply #2 on: 23 Jan 2018, 02:47 pm »
I believe I got it in early 2017, as far as condition and functionality everything looks and works just like it did when I got it, just to let you know I use a mac so I never had to worry about drivers I'm sure the driver on the disc is outdated so you probably have to download the newest one if you're using a PC.
