SOLD: Gustard X20 Dac
0 Members and 1 Guest are viewing this topic. Read 1104 times.
PeteG
« on: 21 Jan 2018, 06:32 pm »
SOLDThe X20 dac has 2 x ESS Technology ES9018 Sabre Reference 32bit.
A great sounding dac for the money. One owner, condition 8/10, original  box and remote.
     I'm asking $550 plus shipping. PP F&F preferred.
Features:
Automatic adaptation master clock technology and Asynchronous master clock technology,Two clock mode can be freely selected.
CPLD programmable logic device. Soft control ES9018.
Three files gain, volume can be adjusted. Attenuation adjustable from 0 to -99DB.
TFT LCD screen, adjustable contrast.
Power supply with two O-type transformers, Digital and Analog independent power supply, and use Discrete Components regulation Voltage stabilization.
Full balance Discrete components Analog Line. Balance / RCA output simultaneously.
Digital Input: balanced Spdif AES/EBU port, RCA, Toslink Optical input and USB.(Key switch)
Power Supply: AC 230V 50 / 60Hz (AC 115V 50 / 60Hz),Power Consumption: <50W
Specification:
DAC:
ESS Technology ES9018 Sabre Reference 32-bit DAC
8 mono to 2 stereo configuration,four D/A converters per channel
Digital Input:
Coaxial, BNC:
PCM:16-24bit /44.1、48、88.2、96、176.4、192 kHz
DOP:DOP64
optical:
DOP:DOP64
AES/EBU:
DOP:DOP64
IIS:
PCM:16-32bit /44.1、48、88.2、96、176.4、192、352.8、384kHz
DSD:DSD64、DSD128、DSD256、DSD512
DOP:DOP64、DOP128 DOP256、DOP512
USB: 16-32bit / 44.1、48、88.2、96、176.4、192、352.8、384 kHz
DSDx64(2.8224MHz)、DSDx128(5.6448MHz)
Analog output:
RCA output level: 2.3 Vrms @0dBFS
XLR Output Level: 4.6 Vrms @0dBFS (XLR interface definition: 1Ground, 2Hot, 3Cold)
Frequency response: 20-20K Hz +/-0.15
« Last Edit: 24 Feb 2018, 06:11 pm by PeteG »
PeteG
Re: Gustard X20 Dac
« Reply #1 on: 7 Feb 2018, 02:03 am »
Bump.
PeteG
Re: Gustard X20 Dac
« Reply #2 on: 23 Feb 2018, 09:11 pm »
Bump.
