CANARY CA 306 Tube amp SOLD
0 Members and 1 Guest are viewing this topic. Read 883 times.
Markwatkiss
« on: 17 Jan 2018, 03:44 pm »
Canary Audio of California hand crafts products designed for the audiophile.Offered for your consideration a CA 306 is a push pull triode configuration with 300B output tubes,Hovland music caps,custom hand wired transformers and independent choke filtered voltage supplies for each channel.
Rated power :             24 wpc
Input impedence:       100,000 ohms
Frequency response: +/- 3db 10 Hz to 60,000 Hz
Tube complement:      4 300B
                                   2 6SN7
                                   1 12 AX7
This amp has less than 100 hours and comes fully tubed.Presents as new.Original list $5495 without tubes.Complete with manual,warranty registration,power cord and factory packaging.
Offered at $1995 plus shipping from 49783.Paypal add 4%.
I would invite you to check my audiogon references under my member name.
« Last Edit: 24 Jan 2018, 09:00 pm by Markwatkiss »
Audiophile58
Re: CANARY CA 306 Tube amp
« Reply #1 on: 19 Jan 2018, 09:56 am »
Hello Mark what kind of tubes brand ?   Where are you located ?   How heavy ?
Thanks ,Paul.
