FS: McIntosh MC58 8 channel amplifier
0 Members and 1 Guest are viewing this topic. Read 695 times.
cnguyen
« on: 15 Jan 2018, 12:41 am »
Up or sale is my McIntosh MC58 in excellent condition comes complete with McIntosh shipping boxes and power cord. The unit has no dings, dents or scratches on the cabinet or front glass. The only flaw is on the top right hand portion of the silver bracket with the worn off corner. You don't see it from 10 feet away. The unit functions perfectly with no issues and yields beautiful Mac sounds. I'm upgraded to a MC205 amp thus the sale.You can bridge the amp for 4 channels/100 watts each or 8 channels at 50 watts each
I’m asking $1275 or best offer. I can take check (personal or bank) or Paypal (3% surcharges)
Feel free to call 303-471-8095 for more infos. Denver Colorado zip 80129.
http://www.audiocircle.com/thumbnails/user/84436/25639/174711_thumbnail.jpeg
http://www.audiocircle.com/thumbnails/user/84436/25639/174710_thumbnail.jpeg
http://www.audiocircle.com/thumbnails/user/84436/25639/174546_thumbnail.jpeg
Specifications
Power Output Per Channel
50 watts into 4 ohm load and 30 watts into 8 ohm load is
the minimum sine wave continuous average power output
per channel, all channels operating.
Power Output Bridged
100 watts into 8 ohm load is the minimum sine wave con-
tinuous average power output per channel, all channels op-
erating.
Rated Power Band
20Hz to 20,000Hz
Total Harmonic Distortion
Maximum Total Harmonic Distortion at any power
level from 250 milliwatts to rated power output is:
0.005% for 4 ohm loads
0.005% for 8 ohm loads
0.005% for Bridged Mode with 8 ohm loads
Dynamic Headroom
1.8dB
Frequency Response
+0, -0.25dB from 20Hz to 20,000Hz
+0, -3.0dB from 10Hz to 100,000Hz
Sensitivity
1 volt (2.5V at level control center detent position)
A-Weighted Signal To Noise Ratio
92dB (112dB below rated output)
Wideband Damping Factor
100 @ 4 ohms
200 @ 8 ohms
Intermodulation Distortion
Maximum Intermodulation Distortion if instanta-
neous peak output per channel does not exceed
twice the rated output, for any combination of fre-
quencies from 20Hz to 20,000Hz, with all channels
operating is:
Input Impedance
20,000 ohms
14
Power Requirements
100 Volts, 50/60Hz at 5.4 amps
110 Volts, 50/60Hz at 4.9 amps
120 Volts, 50/60Hz at 4.7 amps
220 Volts, 50/60Hz at 3.1 amps
230 Volts, 50/60Hz at 3.1 amps
240 Volts, 50/60Hz at 3.1 amps
Note: Refer to the rear panel of the MC58 for the correct
voltage.
Dimensions
Front Panel: 17-1/2 inches (44.5cm) wide, 7-1/16 inches
(17.9cm) high. Depth behind front mounting panel is 20
inches (50.8cm) including clearance for connectors. Panel
clearance required in front of mounting panel is 3/4 inches
(1.9cm).
Weight
40 pounds (18.1Kg) net, 58 pounds (28.3Kg) in shipping
carton
« Last Edit: 18 Jan 2018, 04:19 am by cnguyen »
Roninaudio
  • I don't necessarily agree with everything I say.
Re: FS: McIntosh MC58 multi channel amplifier
« Reply #1 on: 15 Jan 2018, 01:42 am »
Individual for sale items must list an asking price.  Listing the location or zip code is highly recommended.  A buyer may be right around the corner.  Plus a buyer can get an idea of shipping costs if he knows the location.  More.
