SOLD: Heed Quasar Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 1530 times.
Hear Clifford Brown
« on: 14 Jan 2018, 04:38 pm »
Superb phono stage in excellent condition that earns rave reviews.  Built in dual-mono configuration from the power supply upwards. There are two separate amplifier stages for MM and MC cartridges, both being fed from their own regulated power supply.  I used it with a Dynavector XX-2 Mk2 cartridge to great success.  Works with most cartridges.
I'm selling because I’ve recorded all my LPs and going 100% digital streaming.
$800, ships from 98424.  No charge for shipping, buyer pays PayPal fee of 3%.  New retail is $1,200
https://heedaudio.com/modular-line/
Lots of reviews out there, here are a few to check:
http://www.witchdoctor.co.nz/index.php/2012/11/heed-quasar-phono-stagepsu-review/
http://www.positive-feedback.com/Issue57/heed.htm
https://www.stereophile.com/content/heed-audio-quasar-phono-preamplifier
Includes Quasar preamp, Q-PSU power supply, manual, power cable, power cable umbilical between power supply and phono stage, and shipping cartons with outer box.
Specs:
MM input: 3 mV / 47 kOhm / 100 pF
MC input – adjustable
   Sensitivity: 100 uV / 220 uV / 600 uV
   Impedance: 100 Ohm / 220 Ohm / 1 kOhm
Output voltage
   Low Out jacks: 220 mV /100 Ohm
   High out jacks: 775 mV / 22 Ohm
Gain: 50 dB (MM), 62-78 (MC, high out jacks)
Signal-to-noise ratio (A-weighted): 85 dB (MM), 78 dB (MC)
Channel separation: >90 dB
Distortion (THD): <0.08%
Bandwidth: 3 Hz – 150 kHz (+/- 1 dB)
RIAA accuracy: 20 Hz – 20 kHz (+/- 0.5 dB)
Power consumption: < 10 W
Weight: 7 lbs
Dimensions: 3.75” W x 2.75” H x 9” D (each case)
« Last Edit: 21 Mar 2019, 01:38 am by Hear Clifford Brown »
