BDA-1 USB pinouts
0 Members and 1 Guest are viewing this topic. Read 621 times.
ricko01
BDA-1 USB pinouts
« on: 12 Jan 2018, 11:30 pm »
James (or someone else),
Does the the Type B cable that plugs into the BDA-1 need pin 1 (VDC) active (ie I would assume that given the end point isnt a device that needs power then the 5VDC that runs across this pin isnt needed)?
Peter
