Parks Audio Budgie tube phono preamp
0 Members and 1 Guest are viewing this topic. Read 7829 times.
chgolatin2
« on: 6 Jan 2018, 03:59 am »
Letting go of my beloved Parks Audio budgie tube phono preamp, this preamp cost $399 new.  I’m letting it go for $350 with new set of tubes (Amperex 6922) Holland Gold Pins and the original stock tubes Electro Harmonix 6922.  Buyer responsible for shipping cost.  Also, this unit comes with 2 years warranty that transfers over to the new owner.  Details of this beautiful sounding amp below:  Sorry price is firm!  None negotiable~  Please pm me with any questions or inquiries thanks~
Picture of the new tubes (Amperex 6920) is for illustration purposes only~  New tubes have not arrived to my doorstep yet, but they will be included once the purchase has been completed by the new owner :)
   - Single-ended, Class A, all-vacuum-tube audio path
   - Passive RIAA equalization with hand-matched components
   - Uses external 6DJ8/6922 tubes for ease of tube rolling
   - 38 dB gain suitable for MM carts
   - Exacta™ monotonic loading system allows 16 different loading choices
   - Quiet DC filaments
   - Muting circuit at start up to eliminate pops and thermal noise
   - Powered with an external 12V mini-desktop supply
   - Comes with two-year warranty from Parks Audio
   - Made in the USA
The Budgie is a great match with many systems: from classic integrated amps to modern home theater receivers and everything in-between. Contact us with your full system description and phono cartridge used, and we'll make sure that the Budgie is a perfect fit for you.
More about the Exacta adjustable loading and how to get the best sound from your MM cart.
Specifications
Tubes: Two matched 6922 Electro-Harmonix tubes (included)
   - Gain: 38dB (suitable for carts with at least 5mV output)
   - Input Impedance: 47K, adjustable
   - Output Impedance: 6K ohm
   - RIAA Accuracy: +/-0.5dB from 20Hz to 20kHz
   - Distortion: less than 0.1% at 1kHz with 30mVrms input
   - SNR: typically 78dBA with 5mV input
   - Overload: Minimum headroom of 200mVrms at 1kHz
   - Warranty: Two years
   - Power: 7W
   - Input Voltage: 100 to 240VAC 50/60Hz external 12VDC supply
      (EU-UK-OZ adapters free upon request)
   - Weight: 20 oz (570g)
   - Size: 7” x 5” x 4.5” (180 x 130 x 115 mm)
« Last Edit: 6 Jan 2018, 05:17 am by chgolatin2 »
chgolatin2
Re: Parks Audio Budgie tube phono preamp
« Reply #1 on: 10 Jan 2018, 01:02 am »
SOLD~~~!!!  :thumb:
