"What's he building in there" - 6 channels 7200 watts!
0 Members and 1 Guest are viewing this topic. Read 5380 times.
hi5harry
OK. Tom Waits said it first, but I'm curious what crazy systems these six channel amps are going into. Home theater? Tri-amp speakers?
neekomax
Re: "What's he building in there" - 6 channels 7200 watts!
« Reply #1 on: 4 Jan 2018, 03:57 pm »
I'm thinking 6 channels of good power would be perfect for a three way active system, or two way actives with two extra channels for subs. I'd make an active crossover system for the Tempest Fusion 12 kit I have waiting to be built (12' Eminence Delta Pro woofer with 12" SEOS waveguide mated to a compression HF driver).
ohenry
« Reply #2 on: 4 Jan 2018, 05:03 pm »
Good question.  I have the 2-channel version coming and depending on how much I like it, I may do a 6-channel to tri-amp a very large vintage, but upgraded speaker.  I'm on the fence about the gains to be had and simplicity often has rewards (especially when I look at the bank account).  Going with the tri-amp scenario introduces more cables and a crossover.
More stuff sometimes = more stuff, not satisfaction.
MichaelHiFi
« Reply #3 on: 4 Jan 2018, 05:47 pm »
I've got 2 amps coming, one for my friend who turned me on to this thread and a 6 channel SE for me.
Why do I need a 6 channel amp?
I had 2 multi-channel amps, one for surround duties to supplement my 2 channel BMC and one for my Linkwitz mini's that use a 4X10 miniDSP active cross-over to feed the mini's. I gave my Arcam FJ-7 to my stepson which powered the Linkwitz but still have my Emotiva MPS beast.
Now I'll have some flexibility. I can potentially use the AS1200 6 channel to tri-amp the Usher Tower XL's. The Usher has 3 sets of binding posts just for that implementation :) One problem I see with that idea is that my Lindemann DAC-streamer-pre only has 2 sets of outputs. I can split one set of outputs but worry about a system imbalance having a signal split.
But wouldn't it be fun to tri-amp the big Ushers!
Pictured are the Linkwitz mini's that use active DSP and need that 6 channel amp. Yes it's WAY overkill... :duh:
stlrman
« Reply #4 on: 4 Jan 2018, 06:03 pm »
what speaker is that on the right with the ribbon tweeter?
Doublej
« Reply #5 on: 4 Jan 2018, 06:26 pm »
I thought the LX minis required 4 amps. Are you running subwoofers too?
MichaelHiFi
« Reply #6 on: 4 Jan 2018, 07:04 pm »
The speaker on the right is a Clearwave 5R. That tweeter is a Raal with the Amorphous core. The mid is a Scanspeak.
I said it needed the six channel amp but only 4 of those 6 channels but of course I can take the remaining 2 and power my hot-rodded MFW 15 except it already has a dedicated 1000watt amp.
A pic of me and my son with Siegfred at his home. He drove his Linkwitz mini's with a cheap multichannel and and crap wires and it sounded good enough for me to build a pair..  :scratch:
If I don't blow the mini's up (projectile drivers :icon_twisted:) with the AS1200, it might be a fun listen.
ZimAhUm
« Reply #7 on: 5 Jan 2018, 09:01 pm »
Great ideas!
Should be fun!  :o
« Last Edit: 10 Feb 2018, 05:49 am by ZimAhUm »
