Audio/Video Gear and Systems
Tube-o-phile Circle
JakeJ
Rogue sphynx tube rolling
0 Members and 1 Guest are viewing this topic. Read 1466 times.
sugbob21
3 Jan 2018, 04:34 pm »
is it safe to swap out JJ 12 AU7 tubes and replace with Tung Sol 12 AT7 's ?
Can anyone recommend a tube upgrade if I can't ?
thanks
sfox7076
ยป
Re: Rogue sphynx tube rolling
3 Jan 2018, 05:03 pm »
You can, but there is going to be a change in the level of gain. It won't blow anything up, so you can try it, but it is not ideal. Just get some 12AU7s. They made thousands.
Escott1377
Reply #2 on:
3 Jan 2018, 10:25 pm »
I thought it was the other way around due to mu factor and heater current?
In other words, if a 12AT7 is required, a 12AU7 can be a sub and not vice versa based on what the minimum that the circuit will provide?
Tube-o-phile Circle
JakeJ
