SOLD: Burson Conductor headphone amp + preamp + DAC, with Sabre ES9018 chip
0 Members and 1 Guest are viewing this topic. Read 568 times.
ExileSt
Selling my beloved, reference class, Burson so I can switch to a smaller headphone rig. I've used this as both a headphone amp and a preamp -- it shines in both applications.
Cosmetic condition is excellent, with a clean faceplate and some light scuffs/scratches on top. It also features the nicest feer I've ever seen on a component. It does click in between positions on the volume knob but that is normal with the a high-end stepped attenuator.
I've used it with everything from IEMs to full size Sennheiser, Grado, Hifiman, and Fostex. Haven't found a a pairing that's been less than great.
As much as it shines as an amp, I also love it for it's DAC and pre-amp capabilities. It's absolutely the best combo I've found with my Parasound, Adcom and DIY Pass power amps. It offers three analog RCA inputs, and three digital -- coax, USB, and optical TOSLINK.
Go ahead and look at reviews, and you'll find they're all glowing. Power + finesse, and a lot of other audio press superlatives.
The build and components are full on high-end audiophile -- Wima, Philips, Dale, Elna, etc. It's totally discrete class A with nary an IC chip in sight. It has TWO big ole transformers to isolate the digital and analog power stages. And it's basically built like a tank in a hefty aluminum enclosure.
$600 + paypal and shipping from Denver, CO.  (I'm a newer member here at Audio Circle but have loads of feedback at head-fi and eBay.)
« Last Edit: 9 Feb 2018, 09:17 pm by ExileSt »
