0 Members and 1 Guest are viewing this topic. Read 8498 times.
Do you really need the preamp to be active? If not consider the Tortuga LDR3v25.
http://avahifi.com/products/pre-amplifiers/vision-rb-preamplifier
I've tried several passive preamps in the past, and all of them lacked "energy," so I'm not interested in traveling down that road again.Are there any DIY/modular solutions available where one can pick and choose? For instance, I don't want extra stuff in my preamp that I'm paying extra for, but will never use such as a headphone or phono section or HT bypass or dual volume controls or a bunch of extra inputs.
http://www.diyaudio.com/forums/analog-line-level/280458-doug-self-preamp-linear-audio-5-a.htmlA lot of folks have built this one. On my project list. I have received the PCBs already and they are very nicely made.
I'm looking for a preamp with the following features:1. active 2. 2 inputs, 2 outputs3. no tubes4. premium quality volume control 5. Less than $1,200 usedThat's it. Basically, one level beyond a passive preamp. Super simple. No remote. No battery. No frills. Does this exist?
What amp are you currently using ? Does that company make a preamp ? Check out Bill Baker at Response Audio. Great products.
I currently use an Audio GD Master 1 preamp. Incredible preamp and built like a power amp (30 lbs with 3 transformers in it). Just want to try something new, so now I'm on a quest to "downsize" (size-wise) and simplify my system.
I asked you what "AMP" are you using.
