BDP-2 won't advance to next song
0 Members and 1 Guest are viewing this topic. Read 1001 times.
Pundamilia
« on: 28 Dec 2017, 01:30 am »
Has anyone else experienced this? And if so, how did you overcome the problem.  :scratch: :scratch: :scratch:
I am running MM v2.36. Suddenly, my BDP-2 won't automatically go to the next song, but keeps playing the same cut over and over again. If I click on another song, it will play the new song. I have tried undoing the repeat icon and the random icon. I have rebooted, done the update (several times!), cleared the cache, reset the DB and still the issue persists. The only thing that I have not yet tried is to do a factory reset (absolutely last step). Does anyone have any suggestions?
Thanks in advance.
CanadianMaestro
Re: BDP-2 won't advance to next song
« Reply #1 on: 28 Dec 2017, 02:46 pm »
Bizarre.
Reset and turn off auto refresh cache?
gbaby
« Reply #2 on: 28 Dec 2017, 05:34 pm »
Thanks in advance.
Make sure its not on repeat which shows up as an icon.
Pundamilia
« Reply #3 on: 29 Dec 2017, 07:49 pm »
It turns out that there is an MPD option "Single" which is only accessible from the BDP front panel navigation buttons (see last page of MM manual). I must have inadvertently switched the toggle without intending to do so. :duh: I hope someone else learns from my experience and frustration.
Big shout out to Chris (once again!) for resolving the problem.  :thumb: :thumb: :thumb:
