Streaming Tidal or Roon using JRiver server on my network & renderer to my dac
0 Members and 1 Guest are viewing this topic. Read 1006 times.
Tubeburner
I've read all the forums on this subject and I can see the output to JRiver, but I must have a setting wrong because neither one works. I can play music just fine from my library. I can see the renderer in JRiver and loaded a Cubox for Roon as a renderer and Roon sees the Cubox. Any ideas would be appreciated.
Thank you for the help!
richidoo
Seems like you narrowed it down to JRiver. I would upgrade to the latest Roon and latest JRiver, they are always fixing stuff. Tidal is what it is, but you can play Tidal from inside Roon to test. Upgrade Windows too, and reboot everything fresh. Good luck
mikeeastman
Why not drop the JRiver and just use Roon, it has much better SQ and is much easier to use.
